Webhook 2:argons
Hello
How can i Do to create a webhook to transfere Data beetween two argon with différents users.
Thank you
Idir
My recommendation is to not use a webhook at all. Create a new product and add both of those devices to the same product. They can still be claimed to different users, however both users must be team members of the product. Then you can publish and subscribe between the two devices directly.
The alternative, using a webhook, would work like this:
  • User 1 would have a webhook that calls the Particle API to publish to user 2 or use a function. This requires that the webhook embed the access token for user 2 in the webhook.
  • User 2 would have a webhook that calls the Particle API to publish to user 1 or use a function. This requires that the webhook embed the access token for user 1 in the webhook.
Hello
Thank you for you response
I try then I give you feedback.
Idir
THANKS YOU FOR YOUR HELP
IT WORK.
I create a Product shared with 2 users
THANKS again
Idir
