Product Particle Publish CLI
Hello,
Is there a way to particle publish through CLI in which a product webhook would be used vs having to have the webhook setup under the device owners account?
Thank you!
Being able to publish a product event from the CLI is a planned feature, but I don’t have an exact timeline.
It is possible to use a tool like curl to do it right now.
Thank you for your help! If I copy the integration to the owners account and set it to ANY DEVICE in the webhook would the devices associated to the product use this webhook instance or the product webhook instance?
