Visual studio dashboard
is there a way to build my own dashboard using C# or etc… which takes data from photon cloud to make easier UI …???
did anyone try this ???
C# front end :thinking: interesting
Not sure if anyone will invent the wheel again especially when we have HTML/js in place
https://docs.particle.io/datasheets/app-notes/an032-calling-api-from-web-page/
Hello,
As the Cloud API is JSON based, you can definitely make your own dashboard using the existing API calls. Please visit https://docs.particle.io/tutorials/device-os/json to learn more about JSON and while you’re on the site, please take a look at the Cloud API to find the features you’re looking to integrate.
thanks dreamER & lanceseidman for your support
it helps alot…
