Vibration/Impact sensor
Hello there,
I would like to add a vibration/impact sensor to a Tracker one module.
It would be to send an alert in case movement is detected on an asset.
What would be the best hardware to achieve this?
Best!
@fdemonti ,
Depending on what you are intending to do, you may not need any external hardware as the Tracker One has a built-in Inertial Measurement Unit. You can set up events for movement and impact fairly easily.
In fact, triggers on motion and impact do not require any coding as they can be configured in the console.
Hope this helps,
Chip
