Sorry guys, quick update, it dropped this one now, just in case if it helps:
In file included from ../inc/spark_wiring.h:29:0,
from ../inc/application.h:29,
from ats-td.cpp:2:
../../core-common-lib/SPARK_Firmware_Driver/inc/config.h:12:2: warning: #warning "Defaulting to Release Build" [-Wcpp]
In file included from ../../core-common-lib/CC3000_Host_Driver/evnt_handler.h:38:0,
from ../inc/spark_wlan.h:33,
from ../inc/main.h:38,
from ../inc/spark_utilities.h:30,
from ../inc/spark_wiring.h:33,
from ats-td.cpp:2:
../../core-common-lib/CC3000_Host_Driver/socket.h:146:0: warning: "fd_set" redefined [enabled by default]
#define fd_set _types_fd_set_cc3000
In file included from /opt/gcc_arm/arm-none-eabi/include/stdio.h:47:0,
from ats-td.cpp:1:
/opt/gcc_arm/arm-none-eabi/include/sys/types.h:256:0: note: this is the location of the previous definition
from ats-td.cpp:2:
../../core-common-lib/CC3000_Host_Driver/socket.h:162:0: warning: "FD_SET" redefined [enabled by default]
#define FD_SET(fd, fdsetp) __FD_SET (fd, fdsetp)
from ats-td.cpp:1:
/opt/gcc_arm/arm-none-eabi/include/sys/types.h:258:0: note: this is the location of the previous definition
# define FD_SET(n, p) ((p)->fds_bits[(n)/NFDBITS] |= (1L << ((n) % NFDBITS)))
from ats-td.cpp:2:
../../core-common-lib/CC3000_Host_Driver/socket.h:163:0: warning: "FD_CLR" redefined [enabled by default]
#define FD_CLR(fd, fdsetp) __FD_CLR (fd, fdsetp)
from ats-td.cpp:1:
/opt/gcc_arm/arm-none-eabi/include/sys/types.h:259:0: note: this is the location of the previous definition
# define FD_CLR(n, p) ((p)->fds_bits[(n)/NFDBITS] &= ~(1L << ((n) % NFDBITS)))
from ats-td.cpp:2:
../../core-common-lib/CC3000_Host_Driver/socket.h:164:0: warning: "FD_ISSET" redefined [enabled by default]
#define FD_ISSET(fd, fdsetp) __FD_ISSET (fd, fdsetp)
from ats-td.cpp:1:
/opt/gcc_arm/arm-none-eabi/include/sys/types.h:260:0: note: this is the location of the previous definition
# define FD_ISSET(n, p) ((p)->fds_bits[(n)/NFDBITS] & (1L << ((n) % NFDBITS)))
from ats-td.cpp:2:
../../core-common-lib/CC3000_Host_Driver/socket.h:165:0: warning: "FD_ZERO" redefined [enabled by default]
#define FD_ZERO(fdsetp) __FD_ZERO (fdsetp)
from ats-td.cpp:1:
/opt/gcc_arm/arm-none-eabi/include/sys/types.h:261:0: note: this is the location of the previous definition
# define FD_ZERO(p) (__extension__ (void)({ \
ats-td.cpp:468:19: error: too many decimal points in number
lcd->setCursor(0,0);
ats-td.cpp: In function 'void loop()':
ats-td.cpp:445:25: warning: suggest parentheses around comparison in operand of '&' [-Wparentheses]
val = val - '0';
ats-td.cpp:425:8: warning: unused variable 'readit' [-Wunused-variable]
byte i = 0;
make: *** [ats-td.o] Error 1
