Just did a git pull on my firmware folder to update to v0.6.2. I ran make all on the repo after the pull and everything compiled fine but when i tried building with my application firmware i get the following compile errors
In file included from c:\users\ali\documents\src\commercial\library\drivers\relay\relay.h:14:0,
from C:/Users/Ali/Documents/src/Commercial/Library/Devices/device.h:11,
from C:/Users/Ali/Documents/src/Commercial/Library/Devices/device.cpp:8:
../wiring/inc/spark_wiring_arduino_constants.h:40:21: error: expected identifier before numeric constant
#define DEFAULT 1
../system/inc/system_mode.h:30:3: note: in expansion of macro 'DEFAULT'
DEFAULT=0, AUTOMATIC = 1, SEMI_AUTOMATIC = 2, MANUAL = 3, SAFE_MODE=4
../wiring/inc/spark_wiring_arduino_constants.h:40:21: error: expected '}' before numeric constant
#define DEFAULT 1
../wiring/inc/spark_wiring_arduino_constants.h:40:21: error: expected unqualified-id before numeric constant
#define DEFAULT 1
In file included from ../wiring/inc/spark_wiring_system.h:29:0,
from ../wiring/inc/spark_wiring.h:46,
from ./inc/../../../firmware/user/inc/application.h:40,
from ./inc/../../../firmware/user/inc/Particle.h:5,
from c:\users\ali\documents\src\commercial\library\drivers\relay\relay.h:16,
../system/inc/system_mode.h:31:3: error: 'System_Mode_TypeDef' does not name a type
} System_Mode_TypeDef;
../system/inc/system_mode.h:33:22: error: variable or field 'set_system_mode' declared void
void set_system_mode(System_Mode_TypeDef mode);
../system/inc/system_mode.h:33:22: error: 'System_Mode_TypeDef' was not declared in this scope
../system/inc/system_mode.h:34:1: error: 'System_Mode_TypeDef' does not name a type
System_Mode_TypeDef system_mode();
../system/inc/system_mode.h:51:1: error: expected declaration before '}' token
The error seems like a #define conflict. Anyone has suggestions to fix this?
