I try to compile firmware from git repo on ubuntu 12.04. for common-lib and communication lib no issue
but when try to compile core-firmware i got this error
…/src/spark_wiring_interrupts.cpp:59:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:60:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:61:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:62:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:63:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:64:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:65:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:66:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:67:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:68:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:69:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:70:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:71:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:72:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:73:7: error: expected primary-expression before ‘.’ token
…/src/spark_wiring_interrupts.cpp:74:7: error: expected primary-expression before ‘.’ token
make: *** [obj/src/spark_wiring_interrupts.o] Error 1
Looks like you’re using an old version of dfu-util (0.5), the current version is 0.7. The old version doesn’t understand the “:leave” part of the address. I think there is a command line flag for that version of dfu-util that accomplishes the same thing, but I don’t have it in front of me at the moment.
dfu-util does currently only support DFU version 1.0
Filter on vendor = 0x1d50 product = 0x607f
Opening DFU USB device… ID 1d50:607f
Found DFU: [1d50:607f] devnum=0, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/20001Ka,108001Kg"
Claiming USB DFU Interface…
Setting Alternate Setting #0 …
Determining device status: state = dfuDNLOAD-IDLE, status = 0
aborting previous incomplete transfer
dfuIDLE, continuing
Device returned transfer size 1024
No valid DFU suffix signature
Warning: File has no DFU suffix
can’t detach
Resetting USB to switch back to runtime mode
Make sure you’re using “sudo”, and you might need to make sure the firmware is an even number of bytes (dfu quirk). If possible you should really upgrade to the latest version of dfu-util as well.
