Hello!
I’ve now just found the time to start some development with particle, and I’m trying to build the vanilla “latest” branch.
Previously, when I’ve compiled the branch a few months ago on Windows, I wouldn’t really run into any errors, presumably because various -werror flags weren’t enabled in the makefile settings.
However, I’m running Arch Linux 4.6.1-2 with all dependencies installed, and I’m encountering so many warnings as errors. For example, in firmware/services/src/debug.c line 85, there’s a misleading-indentation error when running make from the firmware/ directory level.
I resolved that issue, but when executing make PLATFORM=photon in firmware/modules, I’m encountering way more warnings as errors, such as…
MCU/STM32F2xx/SPARK_Firmware_Driver/src/system_stm32f2xx.c:394:5: error: this 'while' clause does not guard... [-Werror=misleading-indentation]
while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS ) != RCC_CFGR_SWS_PLL);
or the following when the indentation error above was resolved.
./src/photon/wiced/network/LwIP/WWD/FreeRTOS/cpu.h:43:0: error: "BYTE_ORDER" redefined [-Werror]
#define BYTE_ORDER LITTLE_ENDIAN
Are these warnings safe to ignore?
