Using Xenon with 3rd party gateway
I have two questions.
  1. Is it possible to use xenon within existing openthread network based on 3rd part HW. I have a network with router and commissioner role running already in the network and thought about putting xenon into it.
  2. Is it possible to use particle-cli for setting up xenon?
m
In theory yes, but in practice, no, because:
No, the only way to set up a Xenon at this time is using the mobile app. There isn't a setup flow that would allow you to connect to a non-Particle mesh network, so it's not possible at this time.
Hi Rick,
Thanks for the answer.
Are there any plans to extend CLI’s functionality to allow that?
