Use of LocalTimeRK in Australia
@rickkas7 Thanks for this library routine - it takes the pain out of dealing with daylight saving time
I have come across an issue - not sure if its my implementation or an error in the library
When I use the example for Sydney it works correctly
AEST-10AEDT,M10.2.0/2:00:00,M4.1.0/2:00:00"));
However when I use the following code for Adelaide it is out by an hour
“ACST-9:30ACDT,M10.2.0/2:00:00,M4.1.0/2:00:00”
Adelaide is +9:30 ahead of UTC - is this the correct string or should it read ACST-10:30ACDT which gives the correct time but does not seem particularly logical?
@rickkas7 I have explored further and it is something to do with the half hour offset - is my use of -9:30 the correct syntax?
Sydney AEST-10AEDT,M10.2.0/2:00:00,M4.1.0/2:00:00 displays correct time and shows +10:00 on right end of message
Adelaide ACST-9:30ACDT,M10.2.0/2:00:00,M4.1.0/2:00:00 displays time with an error of 1 hour (eg 15:40 rather than 16:40) and shows +8:30 on right end of message (should be +9:30)
Perth AWST-8AWDT,M10.2.0/2:00:00,M4.1.0/2:00:00 displays correct time and shows +8:00 on right end of message
I found the bug that is causing negative POSIX timezone offsets with minutes to be calculated incorrectly.
When running the new unit test for Adelaide, Australia, the start/end of daylight saving is sometimes off by an hour. I’ll fix that before I release a new version.
New version with the fix. The time string for Adelaide should be
"ACST-9:30ACDT,M10.1.0/02:00:00,M4.1.0/03:00:00"
0.0.5 (2021-07-08)
  • Fixed bug in calculation of negative hour offsets that also included minutes
  • Added unit test for Adelaide, Australia
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
