I’m trying to use the IFTTT SMS capabilities to trigger an event on photon. Specifically, when the photon receives a text, start a servo motor. I’ve looked through the guides & decided to use the Particle.function() command to create a function that does my task, but I cannot get the sms message to control anything. I’m getting the IFTTT alert through the phone app, but nothing is happening with the Photon. I got it working for email very easily. I’m trying to do it via the body text. When someone texts, “on” the servo turns on (see image).
Any help would be appreciated, I’m not sure what I’m doing wrong! Should I be using Particle.variable() instead? Again, this worked easily with email.
