Hi Everyone,
I am trying to figure out what would be the best way to read MIDI notes from a device that has
a USB type B output (USB to host) ?
- Using the Boron board
Hi Everyone,
@Alex2, none of the Particle devices can act as USB hosts so what you ask for cannot be done.
Thanks, what would be the best way to “bridge” between the device and the Particle board?
When it’s a proper MIDI device it should also have proper MIDI connectors
I’d think raw MIDI should be doable via RX/TX (including signal adjusment for 3.3V on the Boron).
