My last firmware sent to core has an error and loop with flashing red led
I’ve corrected my firmware but i’m unable to send to core
Is there a way to solve this issue without reset core?
Unless I’m mistaken you only have two options:
ok, i’ve always add this line to avoid this
while(!Serial.available()) SPARK_WLAN_Loop();
I don’t think that’ll save you if your firmware causes a SOS before reaching that line
maybe but i use this as first…
Oh, don’t get me wrong. What you have is great. I prefer the “is D6 high” method so I don’t have to pull up my serial terminal everytime but what you have gets the job done!
can you please explain me this D6 method?
Sure.
You do something like this:
setup()
pinMode(D6, INPUT_PULLUP);
while(digitalRead(D6) == LOW) SPARK_WLAN_Loop();
What that does is set D6 to an INPUT and activate the pullup resistor. It then says "As long as D6 is LOW (ie, you have a wire between D6 and GND) then do the WLAN_LOOP() otherwise continue.
You could also make it activate when D6 is high (like I suggested) by flipping LOW with HIGH above and INPUT_PULLUP with INPUT_PULLDOWN
