When attempting to SSH into the Tachyon using the web console, I am receiving:
"Error connecting to device: Error: Device not found for deviceId"
This indicates that the backend can't find a record of that device connected to the cloud at the moment. What is your device ID? I'll pull some logs to see if the device has intermittent connectivity or something.
I've been power cycling it quite frequently to attempt to get it to connect to a different mobile carrier (it's currently connecting to the one with the poorest connection in my area). However, it has always become avalible on the Particle Console immediately up until today.
Here is the device ID: 422a0600000000007c7314dd
Thanks. I'll take a look.
I took a look at the server side logs for your device connection and I think I identified a bug on our side. If you power cycle the device, it should reconnect. We'll roll out a fix to our server so this doesn't happen again. Thanks for reporting this!
Seems to be working now, thanks!
