Unable to record and Save Wav files in SD card
Hi developers, I am using Argon Particle, I am unable to record and save Wav files, Kindly assist troubleshoot this
// declare implemented functionality
 void redButtonPressed();
 void blackButtonPressed();
 void intializeRTC();
 void adjustRTC_Time();
 void displayRecordingStartup();
 void displayRecording();
 void displayStopRecording();
 void displayFailedSDCardMsg();
 void configureFile_and_Microphone();
 void microphoneRecord();
 void recordingNextClip();
 bool openNewFile();
 void dateTime(uint16_t* date, uint16_t* time);
 SYSTEM_THREAD(ENABLED);
 SYSTEM_MODE(MANUAL);
 void setup(){
     Wire.begin();
     //SdFile::dateTimeCallback(dateTime);
     //set pin modes
     pinMode(D19, OUTPUT);
     digitalWrite(D19,LOW);
     pinMode(A5, OUTPUT);
     digitalWrite(A5,HIGH);
     //set REDButton and BLACKButton pins as INPUT (i.e., read pins)
     //both input pins are pulled LOW by default using 10k resistors
     pinMode(REDButton, INPUT);
     pinMode(BLACKButton, INPUT);
     //attach an interrupt to each button. If the state of the button CHANGEs (i.e., is momentarily pressed)
     //invoke interrupt processing function - redButtonPressed() for REDButton and
     //blackButtonPressed() for BLACKButton
     attachInterrupt(REDButton, redButtonPressed, CHANGE);
     attachInterrupt(BLACKButton, blackButtonPressed, CHANGE);
     //configure SD file structure and PDM microphone parameters
      //start OLED screen
     if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
         Serial.println(F("SSD1306 allocation failed"));
         for(;;);       // Don't proceed, loop forever :)
     intializeRTC();          //initalize real time clock
   adjustRTC_Time();        //correct real-time clock setting
   //delay(7200000);         //wait for 2 hours before starting
 //confugure SD file structure and PDM microphone
 void configureFile_and_Microphone(){
   // Save files in the top-level audio directory (created if needed)
     // Files are 000000.wav, 000001.wav, ...
     sequentialFile
         .withDirName("audio")
         .withNamePattern("%06d.wav");
     int err = Microphone_PDM::instance()
         .withOutputSize(Microphone_PDM::OutputSize::SIGNED_16)
         .withRange(Microphone_PDM::Range::RANGE_2048)
         .withSampleRate(16000)
         .init();
     if (err) {
         Log.error("pdmDecoder.init err=%d", err);
     err = Microphone_PDM::instance().start();
     if (err) {
         Log.error("pdmDecoder.start err=%d", err);
   switch(state) {
     case STATE_WAITING:
       // Waiting for the user to press the RED button. The setup button handler
       // will bump the state into STATE_WAITING_FOR_NOISE
       break;
     //case STATE_WAITING_FOR_NOISE:
       //Waiting for noise before recording starts
       //state = STATE_OPEN_FILE
     //	break;
     case STATE_OPEN_FILE:
       // Open and prep file
       if (openNewFile()) {
         Log.info("starting");
         displayRecording();
         recordingStart = millis();              //set recording start time
         state = STATE_RUNNING;
       else {
         state = STATE_WAITING;
       break;
     case STATE_RUNNING:
       Microphone_PDM::instance().noCopySamples([](void *pSamples, size_t numSamples) {
         curFile.write((uint8_t *)pSamples, Microphone_PDM::instance().getBufferSizeInBytes());
       if (millis() - recordingStart >= RECORDING_TIME) {
         state = STATE_FINISH;
       break;
     case STATE_FINISH:
       Log.info("stopping");
       // Write the actual length to the wave file header
       wavWriter.updateHeaderFromLength(&curFile);
       // Close file
       curFile.close();
             totalClipsRecorded++;
       //stop recording or continue to next clip
       if((recordingInterrupted==1)||(totalClipsRecorded==150)){
       else{
         delay(120000);            //wait 2 minutes before recording next clip
                                   //1  min = 60000 milliseconds
         state=STATE_OPEN_FILE;
       break;
 // button handler for the SETUP button, used to toggle recording on and off
 void redButtonPressed() {
   switch(state) {
     case STATE_WAITING:
       state = STATE_OPEN_FILE;
     break;
 void blackButtonPressed(){
   if(recordingInterrupted==0)
     recordingInterrupted = 1;
     state= STATE_FINISH;
 bool openNewFile() {
   bool success = false;
   Log.info("generating sequential file!");
   // Open the next sequential file
   if (sequentialFile.openFile(&curFile, true)) {
     char name[14];
     curFile.getName(name, sizeof(name));
     if (wavWriter.startFile(&curFile)) {
       Log.info("file opened successfully %s", name);
       success = true;
     else {
       Log.info("could not write header");
   else {
     Log.info("file open failed");
   return success;
 void displayRecordingStartup(){
   display.clearDisplay();
     display.setTextSize(1);                 //Normal 1:1 pixel scale
     display.setTextColor(WHITE);
     display.setCursor(0,20);
     display.println(F("Press RED button to"));
     display.println(F("start recording 20s"));
     display.println(F("clips every 2 mins"));
     // OLED display library initializes this with an Adafruit splash screen.
     display.display();    //this function must be called at the end of display statements
     delay(2000);
 void displayFailedSDCardMsg(){
   display.clearDisplay();                 //clears OLED screen
   display.println(F("Failed to open file"));
     display.println(F("please check that you"));
     display.println(F("have a valid SD card"));
     display.println(F("in card slot"));
     display.display();
 void displayRecording(){
    DateTime now = rtc.now();
     display.setCursor(0,0);
   display.print(F("Clips recorded: "));
     display.println(totalClipsRecorded);
     display.println("================");
   display.println(F("Recording next clip"));
     display.println(F("2 min between clips"));
   display.print(F("Time: "));
   display.print(now.hour(), DEC);
      display.print(':');
      display.print(now.minute(), DEC);
      display.print(':');
      display.println(now.second(), DEC);
     display.println(F("Press BLACK button to"));
     display.println(F("STOP recording"));
     display.display();
 void displayStopRecording(){
     display.println("------------");
     display.println(F(""));
     display.println(F("Recording completed "));
     display.println(F("record new clip"));
     display.display();
 //initialize real-time clock
 void intializeRTC(){
   //start real-time clock
     if (! rtc.begin()) {
         display.println("Couldn't find RTC");
         display.display();
         while (1) delay(10);
 //adjust or correct real-time clock time
 void adjustRTC_Time(){
   //rtc.adjust(DateTime(2025, 1, 12, 12, 52, 00));
   if (rtc.lostPower()) {
     Serial.println("RTC lost power, let's set the time!");
     // When time needs to be set on a new device, or after a power loss, the
     // following line sets the RTC to the date & time this sketch was compiled
     rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
     // This line sets the RTC with an explicit date & time, for example to set
     // January 21, 2014 at 3am you would call:
     // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
 // call back for file timestamps
 void dateTime(uint16_t* date, uint16_t* time) {
   // return date using FAT_DATE macro to format fields
   *date = FAT_DATE(now.year(), now.month(), now.day());
   // return time using FAT_TIME macro to format fields
   *time = FAT_TIME(now.hour(), now.minute(), now.second());
The first step is to enable debug logs
then monitor the USB serial debug log, Without a log it would be impossible to guess what's happening.
