I am trying to create a 10 sensor data logger using a Particle Argon. All of my hardware is working, but I am having trouble logging to an SD card using the argon. I have been using the sdFat and SdCardLogHandlerRK libraries. I included my code at the bottom. I am nominally able to log to my micro-SD card, but I am having two problems:
I cannot get it to create a new file. As it stands, the script that I have writes in a folder it creates on the SD card called logs in a file called "000001.txt". If I reset the Argon, it will just continue writing in that file right after the last line written on it. In an ideal world, I would like to create a new file for each time the logger is reset. I have tried a few things from the examples in the sdFat library (some of which you can see commented out), but none of them have worked. Does anyone have a way of doing this? Do I need a new library?
I have these antecedents before each line that I log onto the SD card like "0000000441 [app.sd] INFO: " (see picture). While I can deal with them later in data processing, it would be a bit easier if I could get rid of them now. Does anyone have a fix for that? Thank you!
This image should show you both the antecedents mentioned in problem 2 and the fact that the log restarts after the argon has been reset.
Here is my Code
#include <SdCardLogHandlerRK.h>
#include <SdFat.h>
int read_pin = A5;
int sig_pin_0 = D3;
int sig_pin_1 = D4;
int sig_pin_2 = D5;
int sig_pin_3 = D6;
int enable_pin = D2;
int val_1_temp[10];
int val_2_temp[10];
int val_3_temp[10];
int val_4_temp[10];
int val_5_temp[10];
int val_6_temp[10];
int val_7_temp[10];
int val_8_temp[10];
int val_9_temp[10];
int val_10_temp[10];
int val_1_print = 0;
int val_2_print = 0;
int val_3_print = 0;
int val_4_print = 0;
int val_5_print = 0;
int val_6_print = 0;
int val_7_print = 0;
int val_8_print = 0;
int val_9_print = 0;
int val_10_print = 0;
String val_1_string;
String val_2_string;
String val_3_string;
String val_4_string;
String val_5_string;
String val_6_string;
String val_7_string;
String val_8_string;
String val_9_string;
String val_10_string;
String value_string;
String str_sep = ", ";
int start_time = 0;
int current_time = 0;
int jj = 0;
int flag_1 = 0;
char name[24];
#define threshold 50
#define resistance 10000
#define num_itter 10
#define gain 2
SYSTEM_THREAD(ENABLED);
const int SD_CHIP_SELECT = D8;
SdFat sd;
// Only log errors and app.sd info level log messages to the SD card
// API change in 0.1.0: You must specify the size of the log handler buffer and call both logHandler.setup() and logHandler.loop()!
SdCardLogHandler<2048> sdLogHandler(sd, SD_CHIP_SELECT, SPI_FULL_SPEED, LOG_LEVEL_ERROR, {
{ "app.sd", LOG_LEVEL_INFO }
// Turn off serial logging in the SdCardLogHandler to avoid logging twice
STARTUP(sdLogHandler.withNoSerialLogging());
// Use LogToSD.info() instead of Log.info(), etc. to write to the SD card
Logger LogToSD("app.sd");
// Log everything to Serial
SerialLogHandler serialLogHandler;
void publish_readings()
current_time = current_time + num_itter;
val_1_print = 0;
val_2_print = 0;
val_3_print = 0;
val_4_print = 0;
val_5_print = 0;
val_6_print = 0;
val_7_print = 0;
val_8_print = 0;
val_9_print = 0;
val_10_print = 0;
//Averaging readings for the past minute
for(int ii = 1; ii <= (num_itter - 1); ii++){
val_1_print = val_1_print + val_1_temp[ii];
val_2_print = val_2_print + val_2_temp[ii];
val_3_print = val_3_print + val_3_temp[ii];
val_4_print = val_4_print + val_4_temp[ii];
val_5_print = val_5_print + val_5_temp[ii];
val_6_print = val_6_print + val_6_temp[ii];
val_7_print = val_7_print + val_7_temp[ii];
val_8_print = val_8_print + val_8_temp[ii];
val_9_print = val_9_print + val_9_temp[ii];
val_10_print = val_10_print + val_10_temp[ii];
val_1_print = val_1_print / num_itter;
val_2_print = val_2_print / num_itter;
val_3_print = val_3_print / num_itter;
val_4_print = val_4_print / num_itter;
val_5_print = val_5_print / num_itter;
val_6_print = val_6_print / num_itter;
val_7_print = val_7_print / num_itter;
val_8_print = val_8_print / num_itter;
val_9_print = val_9_print / num_itter;
val_10_print = val_10_print / num_itter;
if(val_1_print < threshold){
// Removing low voltage values (open circuit)
val_1_string = "NaN";
else{
// Converting to Resistance
val_1_print = ((4095 * gain - val_1_print) * resistance) / val_1_print;
val_1_string = String(val_1_print);
if(val_2_print < threshold){
val_2_string = "NaN";
else{
val_2_print = ((4095 * gain - val_2_print) * resistance) / val_2_print;
val_2_string = String(val_2_print);
if(val_3_print < threshold){
val_3_string = "NaN";
else{
val_3_print = ((4095 * gain - val_3_print) * resistance) / val_3_print;
val_3_string = String(val_3_print);
if(val_4_print < threshold){
val_4_string = "NaN";
else{
val_4_print = ((4095 * gain - val_4_print) * resistance) / val_4_print;
val_4_string = String(val_4_print);
if(val_5_print < threshold){
val_5_string = "NaN";
else{
val_5_print = ((4095 * gain - val_5_print) * resistance) / val_5_print;
val_5_string = String(val_5_print);
if(val_6_print < threshold){
val_6_string = "NaN";
else{
val_6_print = ((4095 * gain - val_6_print) * resistance) / val_6_print;
val_6_string = String(val_6_print);
if(val_7_print < threshold){
val_7_string = "NaN";
else{
val_7_print = ((4095 * gain - val_7_print) * resistance) / val_7_print;
val_7_string = String(val_7_print);
if(val_8_print < threshold){
val_8_string = "NaN";
else{
val_8_print = ((4095 * gain - val_8_print) * resistance) / val_8_print;
val_8_string = String(val_8_print);
if(val_9_print < threshold){
val_9_string = "NaN";
else{
val_9_print = ((4095 * gain - val_9_print) * resistance) / val_9_print;
val_9_string = String(val_9_print);
if(val_10_print < threshold){
val_10_string = "NaN";
else{
val_10_print = ((4095 * gain - val_10_print) * resistance) / val_10_print;
val_10_string = String(val_10_print);
value_string = String(current_time) + str_sep + val_1_string + str_sep + val_2_string + str_sep + val_3_string + str_sep + val_4_string + str_sep + val_5_string +
str_sep + val_6_string + str_sep + val_7_string + str_sep + val_8_string + str_sep + val_9_string + str_sep + val_10_string;
jj = 0;
flag_1 = 1;
void take_readings(){
digitalWrite(enable_pin, LOW);
digitalWrite(sig_pin_0, LOW);
digitalWrite(sig_pin_1, LOW);
digitalWrite(sig_pin_2, LOW);
digitalWrite(sig_pin_3, LOW);
val_1_temp[jj] = analogRead(read_pin);
digitalWrite(sig_pin_0, HIGH);
val_2_temp[jj] = analogRead(read_pin);
digitalWrite(sig_pin_1, HIGH);
val_3_temp[jj] = analogRead(read_pin);
val_4_temp[jj] = analogRead(read_pin);
digitalWrite(sig_pin_2, HIGH);
val_5_temp[jj] = analogRead(read_pin);
val_6_temp[jj] = analogRead(read_pin);
val_7_temp[jj] = analogRead(read_pin);
val_8_temp[jj] = analogRead(read_pin);
digitalWrite(sig_pin_3, HIGH);
val_9_temp[jj] = analogRead(read_pin);
val_10_temp[jj] = analogRead(read_pin);
digitalWrite(enable_pin, HIGH);
jj = jj + 1;
Timer timer_1(10000, publish_readings);
Timer timer_2(1000, take_readings);
//Configuring Pins
pinMode(read_pin, INPUT);
pinMode(sig_pin_0, OUTPUT);
pinMode(sig_pin_1, OUTPUT);
pinMode(sig_pin_2, OUTPUT);
pinMode(sig_pin_3, OUTPUT);
pinMode(enable_pin, OUTPUT);
pinMode(D7, OUTPUT);
digitalWrite(D7, LOW);
//enabling serial communications
// getting the year
char year[4];
String year_str = String(Time.year());
year_str.toCharArray(year, 4);
// getting the month
char month[2];
int month_raw = Time.month();
String month_str = String(month_raw);
if (month_raw < 10){
char temp_1[1];
String temp_2 = "00";
temp_2.toCharArray(month, 2);
month_str.toCharArray(temp_1, 1);
month[1] = temp_1[0];
else{
month_str.toCharArray(month, 2);
// getting the day
char day[2];
int day_raw = Time.day();
String day_str = String(day_raw);
if(day_raw < 10){
char temp_3[1];
String temp_4 = "00";
temp_4.toCharArray(day, 2);
day_str.toCharArray(temp_3, 1);
day[1] = temp_3[0];
else{
day_str.toCharArray(day, 2);
//generating the file name
String name_str = "NSF_TEST_00000000_00.txt";
name_str.toCharArray(name, 24);
name[9] = year[0];
name[10] = year[1];
name[11] = year[2];
name[12] = year[3];
name[13] = month[0];
name[14] = month[1];
name[15] = day[0];
name[16] = day[1];
for (uint8_t i = 0; i < 100; i++) {
name[18] = i/10 + '0';
name[19] = i%10 + '0';
if (sd.exists(name)) {
continue;
// logfile.open(name);
break;
//get current date time
start_time = Time.now();
current_time = start_time;
timer_1.start();
timer_2.start();
// You must call logHandler.setup() from setup()!
sdLogHandler.setup();
String col_names = "UNIX_Datetime_UTC, Probe_1_Resistance_Ohms, Probe_2_Resistance_Ohms, Probe_3_Resistance_Ohms, Probe_4_Resistance_Ohms, Probe_5_Resistance_Ohms, Probe_6_Resistance_Ohms, Probe_7_Resistance_Ohms, Probe_8_Resistance_Ohms, Probe_9_Resistance_Ohms, Probe_10_Resistance_Ohms";
// Log.openLogFile(name);
Log.info(col_names);
LogToSD.info(col_names);
//Serial.println(col_names);
// You must call logHandler.loop() from loop()!
sdLogHandler.loop();
if(flag_1 == 1){
flag_1 = 0;
Log.info(value_string);
LogToSD.info(value_string);
