Hello again,
I have tried implementing your suggestions @ScruffR but I’ve ran into some issues. Following the code through with publishes it appears to be working but no data is being saved on the
file created on the sdcard.
Will continue troubleshooting to see what I’ve done wrong, can you (or anyone else) potentially spot where I am going wrong? I have commented out the bits that I believe I don’t need from Rick’s audio4 code.
#include <SdFat.h>
#include "Particle.h"
// particle compile photon audio4.cpp --target 0.6.3 --saveTo firmware.bin
// ADCDMA - Class to use Photon ADC in DMA Mode
#include "adc_hal.h"
#include "gpio_hal.h"
#include "pinmap_hal.h"
#include "pinmap_impl.h"
#define TEST_FILE_NAME "AudioTest4.bin"
void buttonHandler(system_event_t event, int data); // forward declaration
SdFat sd;
SdFile file;
// The buffer should be around 1024 bytes. However, it also should be a multiple of
// 2 * number of channels = 12, so 1020 is a good choice. The total memory usage is 2x this because
// of double buffers.
const size_t SAMPLE_BUF_SIZE = 1020;
// The audio sample rate. The minimum is probably 8000 for minimally acceptable audio quality.
// Not sure what the maximum rate is, but it's pretty high.
const long SAMPLE_RATE = 44100;
// If you don't hit the setup button to stop recording, this is how long to go before turning it
// off automatically. The limit really is only the disk space available to receive the file.
const unsigned long MAX_RECORDING_LENGTH_MS = 30000;
// This is the IP Address and port that the audioServer.js node server is running on.
IPAddress serverAddr = IPAddress(192,168,2,4);
int serverPort = 7123;
uint16_t samples[SAMPLE_BUF_SIZE];
TCPClient client;
unsigned long recordingStart;
enum State { STATE_WAITING, STATE_CONNECT, STATE_RUNNING, STATE_FINISH };
State state = STATE_WAITING;
class ADCDMA {
public:
ADCDMA(uint16_t *buf, size_t bufSize);
virtual ~ADCDMA();
void start(size_t freqHZ);
void stop();
private:
int pin;
uint16_t *buf;
size_t bufSize;
// Helpful post:
// https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=https%3a%2f%2fmy%2est%2ecom%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fcortex%5fmx%5fstm32%2fstm32f207%20ADC%2bTIMER%2bDMA%20%20Poor%20Peripheral%20Library%20Examples&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=6249
ADCDMA::ADCDMA(uint16_t *buf, size_t bufSize) : pin(pin), buf(buf), bufSize(bufSize) {
ADCDMA::~ADCDMA() {
void ADCDMA::start(size_t freqHZ) {
// Using Dual ADC Regular Simultaneous DMA Mode 1
// Using Timer3. To change timers, make sure you edit all of:
// RCC_APB1Periph_TIM3, TIM3, ADC_ExternalTrigConv_T3_TRGO
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
// Set the pin as analog input
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
// GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
for(int pin = A0; pin <= A5; pin++) {
HAL_Pin_Mode(pin, AN_INPUT);
// Enable the DMA Stream IRQ Channel
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
// 60000000UL = 60 MHz Timer Clock = HCLK / 2
// Even low audio rates like 8000 Hz will fit in a 16-bit counter with no prescaler (period = 7500)
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = (60000000UL / freqHZ) - 1;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_SelectOutputTrigger(TIM3, TIM_TRGOSource_Update); // ADC_ExternalTrigConv_T3_TRGO
TIM_Cmd(TIM3, ENABLE);
ADC_CommonInitTypeDef ADC_CommonInitStructure;
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
// DMA2 Stream0 channel0 configuration
DMA_InitStructure.DMA_Channel = DMA_Channel_0;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)buf;
DMA_InitStructure.DMA_PeripheralBaseAddr = 0x40012308; // CDR_ADDRESS; Packed ADC1, ADC2;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = bufSize;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream0, &DMA_InitStructure);
// Don't enable DMA Stream Half / Transfer Complete interrupt
// Since we want to write out of loop anyway, there's no real advantage to using the interrupt, and as
// far as I can tell, you can't set the interrupt handler for DMA2_Stream0 without modifying
// system firmware because there's no built-in handler for it.
// DMA_ITConfig(DMA2_Stream0, DMA_IT_TC | DMA_IT_HT, ENABLE);
DMA_Cmd(DMA2_Stream0, ENABLE);
// ADC Common Init
ADC_CommonInitStructure.ADC_Mode = ADC_DualMode_RegSimult;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_14Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
// ADC1 configuration
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T3_TRGO;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Left;
ADC_InitStructure.ADC_NbrOfConversion = 3;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, PIN_MAP[A0].adc_channel, 1, ADC_SampleTime_28Cycles);
ADC_RegularChannelConfig(ADC1, PIN_MAP[A2].adc_channel, 2, ADC_SampleTime_28Cycles);
ADC_RegularChannelConfig(ADC1, PIN_MAP[A4].adc_channel, 3, ADC_SampleTime_28Cycles);
// ADC2 configuration - same
ADC_Init(ADC2, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC2, PIN_MAP[A1].adc_channel, 1, ADC_SampleTime_28Cycles);
ADC_RegularChannelConfig(ADC2, PIN_MAP[A3].adc_channel, 2, ADC_SampleTime_28Cycles);
ADC_RegularChannelConfig(ADC2, PIN_MAP[A5].adc_channel, 3, ADC_SampleTime_28Cycles);
// Enable DMA request after last transfer (Multi-ADC mode)
ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
// Enable ADCs
ADC_Cmd(ADC1, ENABLE);
ADC_Cmd(ADC2, ENABLE);
ADC_SoftwareStartConv(ADC1);
void ADCDMA::stop() {
// Stop the ADC
ADC_Cmd(ADC1, DISABLE);
ADC_Cmd(ADC2, DISABLE);
DMA_Cmd(DMA2_Stream0, DISABLE);
// Stop the timer
TIM_Cmd(TIM3, DISABLE);
ADCDMA adcDMA(samples, SAMPLE_BUF_SIZE);
// End ADCDMA
Wire.begin();
sd.begin(A2);
file.open(TEST_FILE_NAME, O_APPEND | O_CREAT | O_TRUNC); //| std::ios::binary
// Register handler to handle clicking on the SETUP button
System.on(button_click, buttonHandler);
pinMode(D7, OUTPUT);
uint16_t *sendBuf = NULL;
switch(state) {
case STATE_WAITING:
// Waiting for the user to press the SETUP button. The setup button handler
// will bump the state into STATE_CONNECT
break;
case STATE_CONNECT:
// Ready to connect to the server via TCP
//if (client.connect(serverAddr, serverPort)) {
// Connected
//adcDMA.start(SAMPLE_RATE);
Particle.publish("starting", PRIVATE);
recordingStart = millis();
digitalWrite(D7, HIGH);
state = STATE_RUNNING;
/*else {
Particle.publish("failed to connect to server", PRIVATE);
break;
case STATE_RUNNING:
Particle.publish("A", PRIVATE);
delay(2000);
Particle.publish("A2", PRIVATE);
delay(2000);
// if (DMA_GetFlagStatus(DMA2_Stream0, DMA_FLAG_HTIF0)) {
// DMA_ClearFlag(DMA2_Stream0, DMA_FLAG_HTIF0);
sendBuf = samples;
Particle.publish("B", PRIVATE);
delay(2000);
Particle.publish("B2", PRIVATE);
if (DMA_GetFlagStatus(DMA2_Stream0, DMA_FLAG_TCIF0)) {
DMA_ClearFlag(DMA2_Stream0, DMA_FLAG_TCIF0);
sendBuf = &samples[SAMPLE_BUF_SIZE / 2];
Particle.publish("C", PRIVATE);
if (sendBuf != NULL) {
// There is a sample buffer to send
// Send here. We're actually sending 1/2 of the samples buffer, but the samples
// are 16 bits and client.write() takes bytes, so there's no division
Particle.publish("File has been succesfully opened", PRIVATE);
int count = file.write(sendBuf,SAMPLE_BUF_SIZE); //My attempt at replacement
//file.print("test");
Particle.publish("file.write", PRIVATE);
file.close();
//int count = client.write((uint8_t *)sendBuf, SAMPLE_BUF_SIZE); //replace with sdFat DMA
if (count == SAMPLE_BUF_SIZE) {
// Success
else
if (count == -16) {
// TCP Buffer full
Particle.publish("buffer full, discarding", PRIVATE);
//else {
// Error
// Particle.publish("error writing %d", PRIVATE);
// state = STATE_FINISH;
if (millis() - recordingStart >= MAX_RECORDING_LENGTH_MS) {
break;
case STATE_FINISH:
digitalWrite(D7, LOW);
//adcDMA.stop();
//client.stop();
Particle.publish("stopping", PRIVATE);
break;
// button handler for the SETUP button, used to toggle recording on and off
void buttonHandler(system_event_t event, int data) {
switch(state) {
case STATE_WAITING:
state = STATE_CONNECT;
break;
case STATE_RUNNING:
break;
I’ve been fairly brutal with cutting out bits of code to try and get it to run all the way through, now it is doing that but not behaving as expected (not really a surprise) so I’m trying to return functionality now…
I’m getting it looping round and succesfully creating the file but it doesn’t contain anything. Is it an issue with having it as a .txt?
