Audio file to SD
Hello,
Sorry to post again but I’m still struggling with getting audio files saved onto SD card.
I am trying to modify https://github.com/rickkas7/photonAudio code to allow me to save directly to an SD card instead of sending over the server.
#include "Particle.h"
// Tested with Adafruit 1713
// Electret Microphone Amplifier - MAX9814 with Auto Gain Control
// https://www.adafruit.com/products/1713
// AR   - No connection
// Out  - Audio out (analog) to Photon A0
// Gain - No connection
// VDD  - 3V3
// GND  - GND
// ADCDMA - Class to use Photon ADC in DMA Mode
#include "adc_hal.h"
#include "gpio_hal.h"
#include "pinmap_hal.h"
#include "pinmap_impl.h"
void buttonHandler(system_event_t event, int data); // forward declaration
// 2048 is a good size for this buffer. This is the number of samples; the number of bytes is twice
// this, but only half the buffer is sent a time, and then each pair of samples is averaged, so
// this results in 1024 byte writes from TCP, which is optimal.
// This uses 4096 bytes of RAM, which is also reasonable.
const size_t SAMPLE_BUF_SIZE = 2048;
// This is the pin the microphone is connected to.
const int SAMPLE_PIN = A0;
// The audio sample rate. The minimum is probably 8000 for minimally acceptable audio quality.
// Not sure what the maximum rate is, but it's pretty high.
const long SAMPLE_RATE = 32000;
// If you don't hit the setup button to stop recording, this is how long to go before turning it
// off automatically. The limit really is only the disk space available to receive the file.
const unsigned long MAX_RECORDING_LENGTH_MS = 30000;
// This is the IP Address and port that the audioServer.js node server is running on.
IPAddress serverAddr = IPAddress(192,168,2,4);
int serverPort = 7123;
uint16_t samples[SAMPLE_BUF_SIZE];
TCPClient client;
unsigned long recordingStart;
enum State { STATE_WAITING, STATE_CONNECT, STATE_RUNNING, STATE_FINISH };
State state = STATE_WAITING;
class ADCDMA {
public:
	ADCDMA(int pin, uint16_t *buf, size_t bufSize);
	virtual ~ADCDMA();
	void start(size_t freqHZ);
	void stop();
private:
	int pin;
	uint16_t *buf;
	size_t bufSize;
// Helpful post:
// https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=https%3a%2f%2fmy%2est%2ecom%2fpublic%2fSTe2ecommunities%2fmcu%2fLists%2fcortex%5fmx%5fstm32%2fstm32f207%20ADC%2bTIMER%2bDMA%20%20Poor%20Peripheral%20Library%20Examples&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&currentviews=6249
ADCDMA::ADCDMA(int pin, uint16_t *buf, size_t bufSize) : pin(pin), buf(buf), bufSize(bufSize) {
ADCDMA::~ADCDMA() {
void ADCDMA::start(size_t freqHZ) {
    // Using Dual ADC Regular Simultaneous DMA Mode 1
	// Using Timer3. To change timers, make sure you edit all of:
	// RCC_APB1Periph_TIM3, TIM3, ADC_ExternalTrigConv_T3_TRGO
	RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC2, ENABLE);
	RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
	// Set the pin as analog input
	// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
	// GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
    HAL_Pin_Mode(pin, AN_INPUT);
	// Enable the DMA Stream IRQ Channel
	NVIC_InitTypeDef NVIC_InitStructure;
	NVIC_InitStructure.NVIC_IRQChannel = DMA2_Stream0_IRQn;
	NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
	NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
	NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
	NVIC_Init(&NVIC_InitStructure);
	// 60000000UL = 60 MHz Timer Clock = HCLK / 2
	// Even low audio rates like 8000 Hz will fit in a 16-bit counter with no prescaler (period = 7500)
	TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
	TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
	TIM_TimeBaseStructure.TIM_Period = (60000000UL / freqHZ) - 1;
	TIM_TimeBaseStructure.TIM_Prescaler = 0;
	TIM_TimeBaseStructure.TIM_ClockDivision = 0;
	TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
	TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
	TIM_SelectOutputTrigger(TIM3, TIM_TRGOSource_Update); // ADC_ExternalTrigConv_T3_TRGO
	TIM_Cmd(TIM3, ENABLE);
	ADC_CommonInitTypeDef ADC_CommonInitStructure;
	ADC_InitTypeDef ADC_InitStructure;
	DMA_InitTypeDef DMA_InitStructure;
	// DMA2 Stream0 channel0 configuration
	DMA_InitStructure.DMA_Channel = DMA_Channel_0;
	DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)buf;
	DMA_InitStructure.DMA_PeripheralBaseAddr =  0x40012308; // CDR_ADDRESS; Packed ADC1, ADC2;
	DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
	DMA_InitStructure.DMA_BufferSize = bufSize;
	DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
	DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
	DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
	DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
	DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
	DMA_InitStructure.DMA_Priority = DMA_Priority_High;
	DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Enable;
	DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
	DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
	DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
	DMA_Init(DMA2_Stream0, &DMA_InitStructure);
	// Don't enable DMA Stream Half / Transfer Complete interrupt
	// Since we want to write out of loop anyway, there's no real advantage to using the interrupt, and as
	// far as I can tell, you can't set the interrupt handler for DMA2_Stream0 without modifying
	// system firmware because there's no built-in handler for it.
	// DMA_ITConfig(DMA2_Stream0, DMA_IT_TC | DMA_IT_HT, ENABLE);
	DMA_Cmd(DMA2_Stream0, ENABLE);
	// ADC Common Init
	ADC_CommonInitStructure.ADC_Mode = ADC_DualMode_RegSimult;
	ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
	ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
	ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
	ADC_CommonInit(&ADC_CommonInitStructure);
	// ADC1 configuration
	ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
	ADC_InitStructure.ADC_ScanConvMode = DISABLE;
	ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
	ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_Rising;
	ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T3_TRGO;
	ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Left;
	ADC_InitStructure.ADC_NbrOfConversion = 1;
	ADC_Init(ADC1, &ADC_InitStructure);
	// ADC2 configuration - same
	ADC_Init(ADC2, &ADC_InitStructure);
	ADC_RegularChannelConfig(ADC1, PIN_MAP[pin].adc_channel, 1, ADC_SampleTime_15Cycles);
    ADC_RegularChannelConfig(ADC2, PIN_MAP[pin].adc_channel, 1, ADC_SampleTime_15Cycles);
	// Enable DMA request after last transfer (Multi-ADC mode)
	ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
	// Enable ADCs
	ADC_Cmd(ADC1, ENABLE);
	ADC_Cmd(ADC2, ENABLE);
	ADC_SoftwareStartConv(ADC1);
void ADCDMA::stop() {
	// Stop the ADC
	ADC_Cmd(ADC1, DISABLE);
	ADC_Cmd(ADC2, DISABLE);
	DMA_Cmd(DMA2_Stream0, DISABLE);
	// Stop the timer
	TIM_Cmd(TIM3, DISABLE);
ADCDMA adcDMA(A0, samples, SAMPLE_BUF_SIZE);
// End ADCDMA
	// Register handler to handle clicking on the SETUP button
	System.on(button_click, buttonHandler);
	pinMode(D7, OUTPUT);
	uint16_t *sendBuf = NULL;
	switch(state) {
	case STATE_WAITING:
		// Waiting for the user to press the SETUP button. The setup button handler
		// will bump the state into STATE_CONNECT
		break;
	case STATE_CONNECT:
		// Ready to connect to the server via TCP
		if (client.connect(serverAddr, serverPort)) {
			// Connected
			adcDMA.start(SAMPLE_RATE);
			Serial.println("starting");
			recordingStart = millis();
			digitalWrite(D7, HIGH);
			state = STATE_RUNNING;
		else {
			Serial.println("failed to connect to server");
		break;
	case STATE_RUNNING:
		if (DMA_GetFlagStatus(DMA2_Stream0, DMA_FLAG_HTIF0)) {
		    DMA_ClearFlag(DMA2_Stream0, DMA_FLAG_HTIF0);
		    sendBuf = samples;
		if (DMA_GetFlagStatus(DMA2_Stream0, DMA_FLAG_TCIF0)) {
		    DMA_ClearFlag(DMA2_Stream0, DMA_FLAG_TCIF0);
		    sendBuf = &samples[SAMPLE_BUF_SIZE / 2];
		if (sendBuf != NULL) {
			// There is a sample buffer to send
			// Average the pairs of samples
			for(size_t ii = 0, jj = 0; ii < SAMPLE_BUF_SIZE / 2; ii += 2, jj++) {
				uint32_t sum = (uint32_t)sendBuf[ii] + (uint32_t)sendBuf[ii + 1];
				sendBuf[jj] = (uint16_t)(sum / 2);
			// Send here. We're actually sending 1/4 of the samples here, 1/2 of the
			// samples buffer, and we've averaged each pair of samples, but the samples
			// are 16 bits and client.write() takes bytes, so only / 2 here
			int count = client.write((uint8_t *)sendBuf, SAMPLE_BUF_SIZE / 2);
			if (count == SAMPLE_BUF_SIZE / 2) {
				// Success
			else
			if (count == -16) {
				// TCP Buffer full
				Serial.printlnf("buffer full, discarding");
			else {
				// Error
				Serial.printlnf("error writing %d", count);
				state = STATE_FINISH;
		if (millis() - recordingStart >= MAX_RECORDING_LENGTH_MS) {
		break;
	case STATE_FINISH:
		digitalWrite(D7, LOW);
		adcDMA.stop();
		client.stop();
		Serial.println("stopping");
		break;
// button handler for the SETUP button, used to toggle recording on and off
void buttonHandler(system_event_t event, int data) {
	switch(state) {
	case STATE_WAITING:
		state = STATE_CONNECT;
		break;
	case STATE_RUNNING:
		break;
I understand from this post :Help with saving .wav file to SDCard
that I should be trying to replace the client.write function with a similar DMA transfer to the SD card but I have so far been unable to produce this…
case STATE_RUNNING:
		    sendBuf = samples;
				// Success
			else
			if (count == -16) {
				// TCP Buffer full
			else {
				// Error
		break;
If anyone could offer some guidance/assistance on this it would be much appreciated.
As some further background:
I require a sampling rate of around 20kHz + but at the moment any rate will be good.
Eventually I would like to save this output as a .wav file on connected SD card using SdFat library
I am using Particle Photon with an ADMP401 microphone
Have you put any more effort into this?
Hi ScruffR,
Yes, thank you for your help I just needed to work through it a bit. I have moved onto writing the wav header and now have two separate programs which record the data stream and write the header… Just working on getting them to work together now but I feel like I am close to outputting a .wav file. Thanks for your assistance!
Good to hear, you got unstuck :+1:
Have you seen my post on your other thread?
