I’ve been trying to flash Nuttx to my Photon, with little in the way of success. Using Particle’s online recovery tool I’m able to flash Tinker on the Photon to get it working again. I’ve made a couple of related posts about it, but I’m still stuck.
$ mkdir nuttxspace
$ cd nuttxspace
$ git clone https://github.com/apache/incubator-nuttx.git nuttx
$ git clone https://github.com/apache/incubator-nuttx-apps apps
$ cd nuttx
$ ./tools/configure.sh -l photon:wlan
$ make menuconfig
I then give it my network’s SSID and password.
$ make
$ sudo dfu-util -d 2b04:d006 -a 0 -s 0x08020000 -D nuttx.bin
The device just continues to blink yellow and if I unplug neither the status light nor the D7 LED comes on, but I can still put the device in DFU mode (which causes it to blink yellow).
dfu-util 0.9
ID 2b04:d006
Claiming USB DFU Interface...
dfuIDLE, continuing
Downloading to address = 0x08020000, size = 345560
Download [=========================] 100% 345560 bytes
Download done.
File downloaded successfully
Does anyone have any idea suggestions? I’d really appreciate it.
Instructions:
/nuttxspace/nuttx/boards/arm/stm32/photon$ cat README.txt
README
This README discusses issues unique to NuttX configurations for the
Particle.io Photon board featuring the STM32F205RG MCU.
The STM32F205RG is a 120 MHz Cortex-M3 operation with 1MB Flash
memory and 128KB RAM. The board includes a Broadcom BCM43362 WiFi.
Contents
- Selecting the Photon board on NuttX
- Configuring NuttX to use your Wireless Router (aka Access Point)
- Flashing NuttX in the Photon board
- Serial console configuration
NOTICE: We will not discuss about toolchains and environment configuration
here, please take a look at STM32F4Discovery board README or other
STM32 board because it should work for Photon board as well.
Let us to consider that you cloned the nuttx and apps repositories, then
follow these steps:
1) Clear your build system before to start:
$ make apps_distclean
$ make distclean
2) Enter inside nuttx/tools and configure to use the Photon board:
$ cd nuttx
$ tools/configure.sh photon:wlan
Since you are already in the root of nuttx/ repository, execute
make menuconfig to define your Wireless Router and your password:
$ make menuconfig
Browser the menus this way:
Application Configuration --->
NSH Library --->
Networking Configuration --->
WAPI Configuration --->
(myApSSID) SSID
(mySSIDpassphrase) Passprhase
Replace the SSID from myApSSID with your wireless router name and
the Passprhase with your WiFi password.
Exit and save your configuration.
Finally just compile NuttX:
$ make
Connect the Photon board in your computer using a MicroUSB cable. Press and
hold both board's buttons (SETUP and RESET), then release the RESET button,
the board will start blinking in the Purple color, waiting until it starts
blinking in Yellow color. Now you can release the SETUP button as well.
1) You can verify if DFU mode in your board is working, using this command:
$ sudo dfu-util -l
dfu-util 0.8
Found DFU: [2b04:d006] ver=0200, devnum=15, cfg=1, intf=0, alt=1, name="@DCT Flash /0x00000000/01*016Kg", serial="00000000010C"
Found DFU: [2b04:d006] ver=0200, devnum=15, cfg=1, intf=0, alt=0, name="@Internal Flash /0x08000000/03*016Ka,01*016Kg,01*064Kg,07*128Kg", serial="00000000010C"
2) Flash the nuttx.bin inside the Internal Flash:
dfu-util 0.8
ID 2b04:d006
dfuIDLE, continuing
Downloading to address = 0x08020000, size = 331348
Download [=========================] 100% 331348 bytes
Download done.
3) Restore the original firmware
If you config to use the stock bootloader of Photon, you may
reload the original firmware with dfu-utils as you like. Otherwise
you must have backuped the whole image beforehand, and reload it
via SWD debug port.
NSH via telnet
After you successfully downloaded nuttx.bin, reset the board and it
automatically connects to the corresponding wifi AP. You may login
your router to see its IP address. Assume that it's 192.168.1.111
Open a terminal on your computer and telnet your Photon:
$ telnet 192.168.1.111
Trying 192.168.1.111...
Connected to 192.168.1.111.
Escape character is '^]'
NuttShell (NSH) NuttX-7.24
nsh>
Connect a USB/Serial 3.3V dongle to GND, TX and RX pins of Photon board.
Then use some serial console client (minicom, picocom, teraterm, etc) confi-
gured to 115200 8n1 without software or hardware flow control.
Reset the board and you should see NuttX starting in the serial.
