I am trying to find a way to send a text message to a particle end point. I have a twillo number, but now with access tokens being deprecated, it seems oauth is about the only option. I want a text with x,y,z as parameters but it seems that Particle will not even pass those to a handler unless I have permission.
I get the idea that tokens were being buried in code and open on particles site but putting in a node that logs in, creates an outh, passes that to particle cloud is just as bad; now my username and pw are there.
Since this is a one off, I can put validation either in Particle or at the end device. If text message is “open 1234” and 1234 is a valid code and open happens….
Thoughts or ideas are appreciated.
