definitely
Oh my god yes!!! @kennethlimcp you are a savior! One more big hurdle down. Thank you so much. I greatly appreciate it. Happy Friday to you.
Hi @kennethlimcp Thank you in advance on your tutorial and help!
I am very new to Node and working on iTerm. I tried the command _sudo npm install -g serialport
looked like installed successfully - I got
> [serialport] Success: "/usr/local/lib/node_modules/serialport/build/Release/serialport.node" is installed via remote > /usr/local/lib > βββ serialport@5.0.0
Then I ran the command sudo npm install -g particle-cli
(btw, what's the difference between sudo npm install -g particle-cli an
d sudo npm install particle-cli
I received three warnings first:
> npm WARN excluding symbolic link test/server/static/ie8-polyfill.js -> ../../../ie8-polyfill.js
> npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
> /usr/local/bin/particle -> /usr/local/lib/node_modules/particle-cli/bin/particle.js
then some successful-ish response:
serialport@4.0.7 install /usr/local/lib/node_modules/particle-cli/node_modules/serialport node-pre-gyp install --fallback-to-build
[serialport] Success: "/usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/Release/serialport.node" is installed via remote
spawn-sync@1.0.15 postinstall /usr/local/lib/node_modules/particle-cli/node_modules/spawn-sync
node postinstall
Then there was a long tree response.
Was this installation successful? What those warnings mean?
My Node.js is v6.11.2
My Macbook is Sierra, Version 10.12.1
Thank you!
Manlin
Hii @kennethlimcp
I tried couple more times and got:
npm WARN excluding symbolic link test/server/static/ie8-polyfill.js -> ../../../ie8-polyfill.js npm WARN deprecated node-uuid@1.4.8: Use uuid module instead /usr/local/bin/particle -> /usr/local/lib/node_modules/particle-cli/bin/particle.js /usr/local/lib βββ particle-cli@1.23.1
What does it mean? Thank you!!
To check that it is properly installed, you can try the command particle --version
The -g
used in npm install
stands for global so that package installed can be called anywhere in the Terminal instead of just the directory you are in.
it showed up 1.23.1
after i ran the command particle --version
guess CLI is installed?
yup.
thank you @kennethlimcp!!
Just adding this for reference. Iβve always been able to install particle-cli with the following:
$ sudo npm install -g --unsafe-perm node-pre-gyp npm serialport particle-cli
Hi guys,
I'm having a problem getting the CLI to work again. It worked for me 6 months ago, but seemed to need a bunch of updating.
I updated Node, current version is 6.11.5
I updated NPM, current version is 5.5.1
I've tried updating particle CLI, and last time it looked like it worked, but when I check the particle version, it has trouble and asks me to do it again.
If I use the command "npm install -g particle-cli"
nothing changes.
Below is what I get when I ask for the particle version:
$ particle -v
! Error loading module 'serialport': Could not locate the bindings file. Tried:
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/serialport.node
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/Debug/serialport.node
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/Release/serialport.node
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/out/Debug/serialport.node
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/Debug/serialport.node
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/out/Release/serialport.node
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/Release/serialport.node
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/default/serialport.node
β /usr/local/lib/node_modules/particle-cli/node_modules/serialport/compiled/6.11.5/darwin/x64/serialport.node
Please reinstall the CLI again using npm install -g particle-cli
Any ideas?
Mac OS Sierra Highβ¦
Still works on Mac OS Sierra.
Sorry, didnβt mention that,
Iβm using OS X 10.11.6
OK, so Im still running circles here, I uninstalled everything, but get the following errors when I install the CLI:
@ParticleIce am I not going to be able to make it work with my OS X version?
Anyone else have any input??
Thx
J
$ npm install -g particle-cli
npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/particle-cli
npm ERR! path /usr/local/lib/node_modules/particle-cli
npm ERR! code EACCES
npm ERR! errno -13
npm ERR! syscall access
npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/particle-cli'
npm ERR! at Error (native)
npm ERR! { Error: EACCES: permission denied, access '/usr/local/lib/node_modules/particle-cli'
npm ERR! stack: 'Error: EACCES: permission denied, access '/usr/local/lib/node_modules/particle-cli'\n at Error (native)',
npm ERR! errno: -13,
npm ERR! code: 'EACCES',
npm ERR! syscall: 'access',
npm ERR! path: '/usr/local/lib/node_modules/particle-cli' }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! A complete log of this run can be found in:
npm ERR! /Users/jimlivingston/.npm/_logs/2017-10-28T18_21_59_040Z-debug.log
Donβt format the hard drive. Apple is sneaky to upgrade Mac Sierra High on Netboot.
try to reinstall it and downgrade Node and NPM version that works.
Try
$sudo npm install -g particle-cli
What do you have?
Try:
sudo npm install -g --unsafe-perm npm particle-cli
EDIT:
Itβs important that you include --unsafe-perm
Thanks, but still no luck.
after I do that, I still have the following when I "particle -v"
$ particle -v
I remember someone having this error before.
OK,
Iβm not sure exactly what did it, but I kept uninstalling, updating, and reinstalling, and eventually got there.
I did an OSX update to latest version, brew install of Node, sudo install of the CLI, and finally it works.
It seems like I had to do everything 3 times, and Iβm not sure what was different in the final working install process, but itβs going.
Thanks all for the help.
J
How to install dfu-util
without Homebrew or MacPorts?
