Sorry it should be npm list -g --depth=0
but thatβs ok.
Can you:
1.) Close the terminal program
2.) Run it again and cd
to the Desktop first
3.) Try npm install -g particle-cli
and see what happens
but thatβs ok.
Can you:
Sorry here it is, ran from ~/Desktop
/usr/local/lib
βββ node-gyp@3.5.0
βββ npm@4.1.2
@kennethlimcp YOU own all my stuff, solved!
So following your advice I literally followed these steps;
I changed into the Desktop folder
cd ~/Desktop
Then I ran;
This was now the response (finally looks like it worked)
npm WARN excluding symbolic link test/server/static/ie8-polyfill.js -> ../../../ie8-polyfill.js
npm WARN deprecated node-uuid@1.4.7: use uuid module instead
/usr/local/bin/particle -> /usr/local/lib/node_modules/particle-cli/bin/particle.js
> serialport@4.0.7 install /usr/local/lib/node_modules/particle-cli/node_modules/serialport
> node-pre-gyp install --fallback-to-build
[serialport] Success: "/usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/Release/serialport.node" is installed via remote
> spawn-sync@1.0.15 postinstall /usr/local/lib/node_modules/particle-cli/node_modules/spawn-sync
> node postinstall
/usr/local/lib
βββ¬ particle-cli@1.20.1
βββ¬ babel-polyfill@6.23.0
β βββ core-js@2.4.1
β βββ regenerator-runtime@0.10.3
βββ babel-runtime@6.23.0
βββ¬ binary-version-reader@0.4.0
β βββ buffer-crc32@0.2.13
β βββ h5.buffers@0.1.1
βββ¬ chalk@1.1.3
β βββ ansi-styles@2.2.1
β βββ escape-string-regexp@1.0.5
β βββ has-ansi@2.0.0
β βββ strip-ansi@3.0.1
β βββ supports-color@2.0.0
βββ cli-spinner@0.2.6
βββ¬ cli-table@0.3.1
β βββ colors@1.0.3
βββ¬ es6-promisify@4.1.0
β βββ es6-promise@3.3.1
βββ¬ form-data@1.0.0-relativepath.2
β βββ async@1.5.2
β βββ¬ combined-stream@1.0.5
β β βββ delayed-stream@1.0.0
β βββ¬ mime-types@2.1.14
β βββ mime-db@1.26.0
βββ¬ glob@5.0.15
β βββ¬ inflight@1.0.6
β β βββ wrappy@1.0.2
β βββ inherits@2.0.3
β βββ¬ minimatch@3.0.3
β β βββ¬ brace-expansion@1.1.6
β β βββ balanced-match@0.4.2
β β βββ concat-map@0.0.1
β βββ once@1.4.0
β βββ path-is-absolute@1.0.1
βββ¬ handlebars@4.0.6
β βββ¬ optimist@0.6.1
β β βββ minimist@0.0.10
β β βββ wordwrap@0.0.3
β βββ¬ source-map@0.4.4
β β βββ amdefine@1.0.1
β βββ¬ uglify-js@2.8.12
β βββ source-map@0.5.6
β βββ uglify-to-browserify@1.0.2
β βββ¬ yargs@3.10.0
β βββ camelcase@1.2.1
β βββ¬ cliui@2.1.0
β β βββ¬ center-align@0.1.3
β β β βββ¬ align-text@0.1.4
β β β β βββ¬ kind-of@3.1.0
β β β β β βββ is-buffer@1.1.5
β β β β βββ longest@1.0.1
β β β β βββ repeat-string@1.6.1
β β β βββ lazy-cache@1.0.4
β β βββ right-align@0.1.3
β β βββ wordwrap@0.0.2
β βββ window-size@0.1.0
βββ hogan.js@2.0.0
βββ¬ inquirer@0.11.4
β βββ ansi-escapes@1.4.0
β βββ ansi-regex@2.1.1
β βββ¬ cli-cursor@1.0.2
β β βββ¬ restore-cursor@1.0.1
β β βββ exit-hook@1.1.1
β β βββ onetime@1.1.0
β βββ cli-width@1.1.1
β βββ¬ figures@1.7.0
β β βββ object-assign@4.1.1
β βββ¬ readline2@1.0.1
β β βββ code-point-at@1.1.0
β β βββ is-fullwidth-code-point@1.0.0
β β βββ mute-stream@0.0.5
β βββ run-async@0.1.0
β βββ rx-lite@3.1.2
β βββ string-width@1.0.2
β βββ through@2.3.8
βββ¬ latest-version@2.0.0
β βββ¬ package-json@2.4.0
β βββ¬ got@5.7.1
β β βββ¬ create-error-class@3.0.2
β β β βββ capture-stack-trace@1.0.0
β β βββ duplexer2@0.1.4
β β βββ is-redirect@1.0.0
β β βββ is-retry-allowed@1.1.0
β β βββ is-stream@1.1.0
β β βββ lowercase-keys@1.0.0
β β βββ node-status-codes@1.0.0
β β βββ¬ parse-json@2.2.0
β β β βββ¬ error-ex@1.3.1
β β β βββ is-arrayish@0.2.1
β β βββ read-all-stream@3.1.0
β β βββ timed-out@3.1.3
β β βββ unzip-response@1.0.2
β β βββ¬ url-parse-lax@1.0.0
β β βββ prepend-http@1.0.4
β βββ¬ registry-auth-token@3.1.0
β β βββ¬ rc@1.1.7
β β βββ minimist@1.2.0
β β βββ strip-json-comments@2.0.1
β βββ registry-url@3.1.0
βββ lodash@3.10.1
βββ moment@2.17.1
βββ¬ node-wifiscanner2@1.2.0
β βββ¬ os-locale@1.4.0
β βββ¬ lcid@1.0.0
β βββ invert-kv@1.0.0
βββ¬ particle-api-js@6.4.3
β βββ form-data@1.0.0-rc4
β βββ¬ stream-http@2.2.1
β β βββ builtin-status-codes@2.0.0
β β βββ to-arraybuffer@1.0.1
β βββ¬ superagent@2.3.0
β β βββ component-emitter@1.2.1
β β βββ cookiejar@2.1.0
β β βββ form-data@1.0.0-rc4
β β βββ formidable@1.1.1
β β βββ methods@1.1.2
β β βββ mime@1.3.4
β β βββ qs@6.4.0
β β βββ¬ readable-stream@2.2.3
β β βββ buffer-shims@1.0.0
β β βββ isarray@1.0.0
β β βββ process-nextick-args@1.0.7
β β βββ string_decoder@0.10.31
β βββ superagent-prefix@0.0.2
βββ¬ particle-commands@0.2.9
β βββ¬ mkdirp@0.5.1
β β βββ minimist@0.0.8
β βββ underscore@1.8.3
β βββ winreg@1.2.3
βββ¬ particle-library-manager@0.1.10
β βββ app-root-path@1.4.0
β βββ¬ async@2.1.5
β β βββ lodash@4.17.4
β βββ babel-plugin-array-includes@2.0.3
β βββ babel-plugin-transform-runtime@6.23.0
β βββ¬ fs-extra@0.30.0
β β βββ graceful-fs@4.1.11
β β βββ jsonfile@2.4.0
β β βββ klaw@1.3.1
β βββ¬ gunzip-maybe@1.4.0
β β βββ¬ browserify-zlib@0.1.4
β β β βββ pako@0.2.9
β β βββ is-deflate@1.0.0
β β βββ is-gzip@1.0.0
β β βββ¬ peek-stream@1.1.1
β β β βββ¬ duplexify@3.5.0
β β β β βββ stream-shift@1.0.0
β β β βββ¬ through2@0.5.1
β β β βββ¬ readable-stream@1.0.34
β β β β βββ isarray@0.0.1
β β β βββ xtend@3.0.0
β β βββ pumpify@1.3.5
β βββ¬ properties-parser@0.3.1
β β βββ string.prototype.codepointat@0.2.0
β βββ¬ superagent@1.8.5
β β βββ cookiejar@2.0.6
β β βββ¬ form-data@1.0.0-rc3
β β β βββ async@1.5.2
β β βββ formidable@1.0.17
β β βββ qs@2.3.3
β β βββ¬ readable-stream@1.0.27-1
β β βββ reduce-component@1.0.1
β βββ¬ tar-fs@1.15.1
β β βββ chownr@1.0.1
β β βββ¬ pump@1.0.2
β β βββ¬ end-of-stream@1.2.0
β β βββ once@1.3.3
β βββ¬ tar-stream@1.5.2
β β βββ bl@1.2.0
β β βββ¬ end-of-stream@1.0.0
β β βββ once@1.3.3
β βββ tmp@0.0.28
β βββ¬ verror@1.9.0
β βββ assert-plus@1.0.0
β βββ core-util-is@1.0.2
β βββ extsprintf@1.3.0
βββ¬ request@2.75.1-relativepath.1
β βββ aws-sign2@0.6.0
β βββ aws4@1.6.0
β βββ¬ bl@1.1.2
β β βββ readable-stream@2.0.6
β βββ caseless@0.11.0
β βββ extend@3.0.0
β βββ forever-agent@0.6.1
β βββ¬ har-validator@2.0.6
β β βββ¬ is-my-json-valid@2.16.0
β β β βββ generate-function@2.0.0
β β β βββ¬ generate-object-property@1.2.0
β β β β βββ is-property@1.0.2
β β β βββ jsonpointer@4.0.1
β β βββ¬ pinkie-promise@2.0.1
β β βββ pinkie@2.0.4
β βββ¬ hawk@3.1.3
β β βββ boom@2.10.1
β β βββ cryptiles@2.0.5
β β βββ hoek@2.16.3
β β βββ sntp@1.0.9
β βββ¬ http-signature@1.1.1
β β βββ assert-plus@0.2.0
β β βββ¬ jsprim@1.3.1
β β β βββ extsprintf@1.0.2
β β β βββ json-schema@0.2.3
β β β βββ verror@1.3.6
β β βββ¬ sshpk@1.11.0
β β βββ bcrypt-pbkdf@1.0.1
β β βββ dashdash@1.14.1
β β βββ ecc-jsbn@0.1.1
β β βββ getpass@0.1.6
β β βββ jodid25519@1.0.2
β β βββ jsbn@0.1.1
β β βββ tweetnacl@0.14.5
β βββ is-typedarray@1.0.0
β βββ isstream@0.1.2
β βββ json-stringify-safe@5.0.1
β βββ node-uuid@1.4.7
β βββ oauth-sign@0.8.2
β βββ qs@6.2.3
β βββ stringstream@0.0.5
β βββ¬ tough-cookie@2.3.2
β β βββ punycode@1.4.1
β βββ tunnel-agent@0.4.3
βββ semver@5.3.0
βββ¬ serialport@4.0.7
β βββ bindings@1.2.1
β βββ¬ commander@2.9.0
β β βββ graceful-readlink@1.0.1
β βββ¬ debug@2.6.2
β β βββ ms@0.7.2
β βββ¬ lie@3.1.1
β β βββ immediate@3.0.6
β βββ nan@2.5.1
β βββ¬ node-pre-gyp@0.6.32
β β βββ¬ mkdirp@0.5.1
β β β βββ minimist@0.0.8
β β βββ¬ nopt@3.0.6
β β β βββ abbrev@1.0.9
β β βββ¬ npmlog@4.0.1
β β β βββ¬ are-we-there-yet@1.1.2
β β β β βββ delegates@1.0.0
β β β β βββ¬ readable-stream@2.2.2
β β β β βββ buffer-shims@1.0.0
β β β β βββ core-util-is@1.0.2
β β β β βββ inherits@2.0.3
β β β β βββ isarray@1.0.0
β β β β βββ process-nextick-args@1.0.7
β β β β βββ string_decoder@0.10.31
β β β β βββ util-deprecate@1.0.2
β β β βββ console-control-strings@1.1.0
β β β βββ¬ gauge@2.7.2
β β β β βββ aproba@1.0.4
β β β β βββ has-unicode@2.0.1
β β β β βββ object-assign@4.1.0
β β β β βββ signal-exit@3.0.2
β β β β βββ¬ string-width@1.0.2
β β β β β βββ code-point-at@1.1.0
β β β β β βββ¬ is-fullwidth-code-point@1.0.0
β β β β β βββ number-is-nan@1.0.1
β β β β βββ¬ strip-ansi@3.0.1
β β β β β βββ ansi-regex@2.0.0
β β β β βββ supports-color@0.2.0
β β β β βββ wide-align@1.1.0
β β β βββ set-blocking@2.0.0
β β βββ¬ rc@1.1.6
β β β βββ deep-extend@0.4.1
β β β βββ ini@1.3.4
β β β βββ minimist@1.2.0
β β β βββ strip-json-comments@1.0.4
β β βββ¬ request@2.79.0
β β β βββ aws-sign2@0.6.0
β β β βββ aws4@1.5.0
β β β βββ caseless@0.11.0
β β β βββ¬ combined-stream@1.0.5
β β β β βββ delayed-stream@1.0.0
β β β βββ extend@3.0.0
β β β βββ forever-agent@0.6.1
β β β βββ¬ form-data@2.1.2
β β β β βββ asynckit@0.4.0
β β β βββ¬ har-validator@2.0.6
β β β β βββ¬ chalk@1.1.3
β β β β β βββ ansi-styles@2.2.1
β β β β β βββ escape-string-regexp@1.0.5
β β β β β βββ¬ has-ansi@2.0.0
β β β β β β βββ ansi-regex@2.0.0
β β β β β βββ¬ strip-ansi@3.0.1
β β β β β βββ supports-color@2.0.0
β β β β βββ¬ is-my-json-valid@2.15.0
β β β β β βββ generate-function@2.0.0
β β β β β βββ¬ generate-object-property@1.2.0
β β β β β β βββ is-property@1.0.2
β β β β β βββ jsonpointer@4.0.0
β β β β β βββ xtend@4.0.1
β β β β βββ¬ pinkie-promise@2.0.1
β β β β βββ pinkie@2.0.4
β β β βββ¬ hawk@3.1.3
β β β β βββ boom@2.10.1
β β β β βββ cryptiles@2.0.5
β β β β βββ hoek@2.16.3
β β β β βββ sntp@1.0.9
β β β βββ¬ http-signature@1.1.1
β β β β βββ assert-plus@0.2.0
β β β β βββ¬ jsprim@1.3.1
β β β β β βββ extsprintf@1.0.2
β β β β β βββ json-schema@0.2.3
β β β β β βββ verror@1.3.6
β β β β βββ¬ sshpk@1.10.1
β β β β βββ asn1@0.2.3
β β β β βββ assert-plus@1.0.0
β β β β βββ bcrypt-pbkdf@1.0.0
β β β β βββ dashdash@1.14.1
β β β β βββ ecc-jsbn@0.1.1
β β β β βββ getpass@0.1.6
β β β β βββ jodid25519@1.0.2
β β β β βββ jsbn@0.1.0
β β β β βββ tweetnacl@0.14.4
β β β βββ is-typedarray@1.0.0
β β β βββ isstream@0.1.2
β β β βββ json-stringify-safe@5.0.1
β β β βββ¬ mime-types@2.1.13
β β β β βββ mime-db@1.25.0
β β β βββ oauth-sign@0.8.2
β β β βββ qs@6.3.0
β β β βββ stringstream@0.0.5
β β β βββ¬ tough-cookie@2.3.2
β β β β βββ punycode@1.4.1
β β β βββ tunnel-agent@0.4.3
β β β βββ uuid@3.0.1
β β βββ¬ rimraf@2.5.4
β β β βββ¬ glob@7.1.1
β β β βββ fs.realpath@1.0.0
β β β βββ¬ inflight@1.0.6
β β β β βββ wrappy@1.0.2
β β β βββ¬ minimatch@3.0.3
β β β β βββ¬ brace-expansion@1.1.6
β β β β βββ balanced-match@0.4.2
β β β β βββ concat-map@0.0.1
β β β βββ¬ once@1.4.0
β β β βββ path-is-absolute@1.0.1
β β βββ semver@5.3.0
β β βββ¬ tar@2.2.1
β β β βββ block-stream@0.0.9
β β β βββ¬ fstream@1.0.10
β β β β βββ graceful-fs@4.1.11
β β βββ¬ tar-pack@3.3.0
β β βββ¬ debug@2.2.0
β β β βββ ms@0.7.1
β β βββ¬ fstream-ignore@1.0.5
β β βββ¬ once@1.3.3
β β βββ¬ readable-stream@2.1.5
β β βββ uid-number@0.0.6
β βββ¬ object.assign@4.0.4
β βββ¬ define-properties@1.1.2
β β βββ foreach@2.0.5
β βββ function-bind@1.1.0
β βββ object-keys@1.0.11
βββ¬ softap-setup@1.1.4
β βββ¬ nconf@0.7.2
β β βββ async@0.9.2
β β βββ ini@1.3.4
β β βββ¬ yargs@3.15.0
β β βββ window-size@0.1.4
β βββ¬ node-rsa@0.2.30
β βββ asn1@0.2.3
β βββ lodash@3.3.0
βββ¬ temp@0.8.3
β βββ os-tmpdir@1.0.2
β βββ rimraf@2.2.8
βββ when@3.7.8
βββ xtend@4.0.1
βββ¬ yargs@5.0.0
β βββ¬ cliui@3.2.0
β β βββ wrap-ansi@2.1.0
β βββ decamelize@1.2.0
β βββ get-caller-file@1.0.2
β βββ lodash.assign@4.2.0
β βββ¬ read-pkg-up@1.0.1
β β βββ¬ read-pkg@1.1.0
β β βββ load-json-file@1.1.0
β β βββ¬ normalize-package-data@2.3.6
β β β βββ hosted-git-info@2.2.0
β β β βββ¬ is-builtin-module@1.0.0
β β β β βββ builtin-modules@1.1.1
β β β βββ¬ validate-npm-package-license@3.0.1
β β β βββ¬ spdx-correct@1.0.2
β β β β βββ spdx-license-ids@1.2.2
β β β βββ spdx-expression-parse@1.0.4
β β βββ path-type@1.1.0
β βββ require-directory@2.1.1
β βββ require-main-filename@1.0.1
β βββ which-module@1.0.0
β βββ window-size@0.2.0
β βββ y18n@3.2.1
β βββ¬ yargs-parser@3.2.0
β βββ camelcase@3.0.0
βββ¬ yeoman-environment@1.6.6
β βββ diff@2.2.3
β βββ¬ globby@4.1.0
β β βββ¬ array-union@1.0.2
β β β βββ array-uniq@1.0.3
β β βββ arrify@1.0.1
β β βββ glob@6.0.4
β β βββ pify@2.3.0
β βββ¬ grouped-queue@0.3.3
β βββ¬ inquirer@1.2.3
β β βββ cli-width@2.1.0
β β βββ¬ external-editor@1.1.1
β β β βββ¬ spawn-sync@1.0.15
β β β β βββ¬ concat-stream@1.6.0
β β β β β βββ typedarray@0.0.6
β β β β βββ os-shim@0.1.3
β β β βββ tmp@0.0.29
β β βββ mute-stream@0.0.6
β β βββ run-async@2.3.0
β β βββ rx@4.1.0
β βββ lodash@4.17.4
β βββ log-symbols@1.0.2
β βββ¬ mem-fs@1.1.3
β β βββ¬ vinyl@1.2.0
β β β βββ clone@1.0.2
β β β βββ clone-stats@0.0.1
β β β βββ replace-ext@0.0.1
β β βββ¬ vinyl-file@2.0.0
β β βββ¬ strip-bom@2.0.0
β β β βββ is-utf8@0.2.1
β β βββ¬ strip-bom-stream@2.0.0
β β βββ first-chunk-stream@2.0.0
β βββ text-table@0.2.0
β βββ¬ untildify@2.1.0
β βββ os-homedir@1.0.2
βββ¬ yeoman-generator@0.24.1
βββ async@2.1.5
βββ¬ class-extend@0.1.2
β βββ object-assign@2.1.1
βββ¬ cross-spawn@4.0.2
β βββ¬ lru-cache@4.0.2
β β βββ pseudomap@1.0.2
β β βββ yallist@2.1.0
β βββ¬ which@1.2.12
β βββ isexe@1.1.2
βββ¬ dargs@4.1.0
βββ¬ dateformat@1.0.12
β βββ get-stdin@4.0.1
β βββ¬ meow@3.7.0
β βββ¬ camelcase-keys@2.1.0
β β βββ camelcase@2.1.1
β βββ¬ loud-rejection@1.6.0
β β βββ¬ currently-unhandled@0.4.1
β β β βββ array-find-index@1.0.2
β βββ map-obj@1.0.1
β βββ¬ redent@1.0.0
β β βββ¬ indent-string@2.1.0
β β β βββ¬ repeating@2.0.1
β β β βββ is-finite@1.0.2
β β βββ strip-indent@1.0.1
β βββ trim-newlines@1.0.0
βββ detect-conflict@1.0.1
βββ¬ error@7.0.2
β βββ string-template@0.2.1
βββ find-up@1.1.2
βββ¬ github-username@2.1.0
β βββ gh-got@2.4.0
βββ¬ glob@7.1.1
βββ¬ gruntfile-editor@1.2.1
β βββ¬ ast-query@2.0.0
β β βββ¬ acorn-jsx@3.0.1
β β β βββ acorn@3.3.0
β β βββ¬ escodegen-wallaby@1.6.10
β β β βββ esprima@2.7.3
β β β βββ estraverse@1.9.3
β β β βββ esutils@2.0.2
β β β βββ¬ optionator@0.8.2
β β β β βββ deep-is@0.1.3
β β β β βββ fast-levenshtein@2.0.6
β β β β βββ levn@0.3.0
β β β β βββ prelude-ls@1.1.2
β β β β βββ type-check@0.3.2
β β β β βββ wordwrap@1.0.0
β β β βββ source-map@0.2.0
β β βββ traverse@0.6.6
β βββ lodash@4.17.4
βββ¬ html-wiring@1.2.0
β βββ¬ cheerio@0.19.0
β β βββ¬ css-select@1.0.0
β β β βββ boolbase@1.0.0
β β β βββ css-what@1.0.0
β β β βββ domutils@1.4.3
β β β βββ nth-check@1.0.1
β β βββ¬ dom-serializer@0.1.0
β β β βββ domelementtype@1.1.3
β β βββ entities@1.1.1
β β βββ¬ htmlparser2@3.8.3
β β βββ domelementtype@1.3.0
β β βββ domhandler@2.3.0
β β βββ domutils@1.5.1
β β βββ entities@1.0.0
β β βββ¬ readable-stream@1.1.14
β βββ¬ detect-newline@1.0.3
βββ¬ istextorbinary@2.1.0
β βββ binaryextensions@2.0.0
β βββ editions@1.3.3
β βββ textextensions@2.0.1
βββ lodash@4.17.4
βββ¬ mem-fs-editor@2.3.0
β βββ commondir@1.0.1
β βββ ejs@2.5.6
β βββ glob@7.1.1
β βββ¬ multimatch@2.1.0
β βββ array-differ@1.0.0
βββ¬ nopt@3.0.6
β βββ abbrev@1.1.0
βββ path-exists@2.1.0
βββ pretty-bytes@3.0.1
βββ read-chunk@1.0.1
βββ¬ rimraf@2.6.1
β βββ glob@7.1.1
βββ¬ run-async@2.3.0
β βββ is-promise@2.1.0
βββ¬ shelljs@0.7.7
β βββ glob@7.1.1
β βββ interpret@1.0.1
β βββ¬ rechoir@0.6.2
β βββ¬ resolve@1.3.2
β βββ path-parse@1.0.5
βββ through2@2.0.3
βββ¬ underscore.string@3.3.4
β βββ sprintf-js@1.0.3
βββ user-home@2.0.0
βββ yeoman-assert@2.2.3
βββ¬ yeoman-test@1.6.0
β βββ lodash@4.17.4
β βββ¬ sinon@1.17.7
β βββ formatio@1.1.1
β βββ lolex@1.3.2
β βββ samsam@1.1.2
β βββ¬ util@0.10.3
β βββ inherits@2.0.1
βββ yeoman-welcome@1.0.1
Look like it has finally worked;
****:Desktop noofny$ particle
Welcome to the Particle Command line utility!
Version 1.20.1
https://github.com/spark/particle-cli
Perfect
@kennethlimcp - when a stranger steps in and shares the pain of a n00b for nothing more than to help another, you realise you are in a true community.
Thank you for your time listening and guiding. For you or anyone else, if thereβs anything I have left out from the resolution here for others, call it out so I can stick in here.
Hello @kennethlimcp,
I am having some serious issues with installingnpm install -g particle-cli
. I have tried all of the above numerous times and am at a loss. Here is my most recent effort based upon what you had gone through with noofny above. Would you be able to help me resolve this? Please help!
brain:~ Zeytin$ cd ~/Desktop
brain:Desktop Zeytin$ npm install -g particle-cli
/usr/local/lib/node_modules/npm/node_modules/npm-package-arg/npa.js:6
let url
SyntaxError: Unexpected strict mode reserved word
at Module._compile (module.js:439:25)
at Object.Module._extensionsβ¦js (module.js:474:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.require (module.js:364:17)
at require (module.js:380:17)
at Object. (/usr/local/lib/node_modules/npm/node_modules/npm-registry-client/lib/access.js:5:11)
at Module._compile (module.js:456:26)
Weird errors. What does node --version
say?
Thank you for the reply! I am stumped and have tried many different things over the last few weeks but no luck.
Version is v0.10.29
The recommended is higher than v0.10.29
you might want to upgrade nodejs here: https://nodejs.org/en/download/
and try to install again.
Tried to install the latest version before but had no luck so I saw above that folks were trying the v.0.10.29 with success so I tried that. I just downloaded the current version and this is the reply from Terminal:
brain:~ Zeytin$ sudo npm install -g particle-cli
Password:
npm WARN excluding symbolic link test/server/static/ie8-polyfill.js -> β¦/β¦/β¦/ie8-polyfill.js
npm WARN deprecated node-uuid@1.4.8: Use uuid module instead
/usr/local/lib
βββ¬ particle-cli@1.23.1
βββ form-data@1.0.0-relativepath.2
βββ¬ particle-api-js@6.5.0
β βββ stream-http@2.2.1
βββ request@2.75.1-relativepath.1
what does particle --version
say?
brain:~ Zeytin$ particle --version
! Error loading module 'serialport': Module version mismatch. Expected 48, got 57.
Please reinstall the CLI again using npm install -g particle-cli
cliftons-brain:~ Zeytin$ npm install -g particle-cli
npm WARN checkPermissions Missing write access to /usr/local/lib/node_modules/particle-cli
/usr/local/lib
βββ particle-cli@1.23.1
npm ERR! Darwin 16.6.0
npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "install" "-g" "particle-cli"
npm ERR! node v6.11.2
npm ERR! npm v3.10.10
npm ERR! path /usr/local/lib/node_modules/particle-cli
npm ERR! code EACCES
npm ERR! errno -13
npm ERR! syscall access
npm ERR! Error: EACCES: permission denied, access '/usr/local/lib/node_modules/particle-cli'
npm ERR! at Error (native)
npm ERR! { Error: EACCES: permission denied, access '/usr/local/lib/node_modules/particle-cli'
npm ERR! errno: -13,
npm ERR! code: 'EACCES',
npm ERR! syscall: 'access',
npm ERR! path: '/usr/local/lib/node_modules/particle-cli' }
npm ERR!
npm ERR! Please try running this command again as root/Administrator.
npm ERR! Please include the following file with any support request:
npm ERR! /Users/Zeytin/npm-debug.log
do a npm uninstall -g particle-cli
followed by npm install -g particle-cli
again to see if it works.
You also need to fix the permissions issue for npm with the instructions here: https://docs.npmjs.com/getting-started/fixing-npm-permissions
Ok, I just did the uninstall and wow there was a lot of verbiage! then tried the install and got the below... I'll try the link in just a moment.
/usr/local/lib
npm ERR! errno -13
npm ERR!
Hi @kennethlimcp,
I did this today actually. I will certainly do it again but which option do you think is best? I did the first option on the video earlier. Should I try the option 3?
Tried the 3rd option (brew install) The below was the outcome... Sorry I am sure this is super annoying but I really do appreciate it and this has been halting my progress.
brain:~ Zeytin$ /usr/bin/ruby -e "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/master/install)"
==> This script will install:
/usr/local/bin/brew
/usr/local/share/doc/homebrew
/usr/local/share/man/man1/brew.1
/usr/local/share/zsh/site-functions/_brew
/usr/local/etc/bash_completion.d/brew
/usr/local/Homebrew
Press RETURN to continue or any other key to abort
==> /usr/bin/sudo /bin/mkdir -p /Library/Caches/Homebrew
Password:
==> /usr/bin/sudo /bin/chmod g+rwx /Library/Caches/Homebrew
==> /usr/bin/sudo /usr/sbin/chown Zeytin /Library/Caches/Homebrew
==> Downloading and installing Homebrew...
remote: Total 0 (delta 0), reused 0 (delta 0), pack-reused 0
HEAD is now at 1cae6dd6 Merge pull request #2997 from ilovezfs/non-libraries
Updated 1 tap (homebrew/core).
==> Cleaning up /Library/Caches/Homebrew...
==> Migrating /Library/Caches/Homebrew to /Users/Zeytin/Library/Caches/Homebrew.
==> Deleting /Library/Caches/Homebrew...
==> Updated Formulae
imagemagick imagemagick@6 kubernetes-cli node-build
==> Installation successful!
==> Homebrew has enabled anonymous aggregate user behaviour analytics.
Read the analytics documentation (and how to opt-out) here:
Anonymous Analytics β Homebrew Documentation
==> Next steps:
brew help
to get startedbrain:~ Zeytin$ brew install node
Warning: node 8.2.1 is already installed, it's just not linked.
You can use brew link node
to link this version.
/usr/local/lib
npm ERR! errno -13
npm ERR!
Try sudo npm install -g particle-cli
Hi @kennethlimcp,
Thank you for the reply. Here is what the outcome is:
Password:
/usr/local/lib
Does that mean it was successful?
Try with particle --version
Says 1.23.1
So we did it?!?
