Tutorial: Enable GPIO Serial on RPi 3
Hello everyone.
[Today I found a very nice tutorial to enable UART (GPIO) serial on Raspberry Pi 3 and Pi Zero W.][1]
To summarize, here are the commands I did to enable serial (/dev/ttyS0) on my Raspberry Pi 3:
$ sudo -s
$ echo "enable_uart=1" >> /boot/config.txt
$ systemctl stop serial-getty@ttyS0.service
$ systemctl disable serial-getty@ttyS0.service
$ nano /boot/cmdline.txt #Remove console=serial0,115200
After a reboot you should be able to use /dev/ttyS0
Quick test:
$ sudo apt install screen # Install screen if you don't have it already
$ sudo screen /dev/ttyS0 # Open the port for viewing
Now you should be able to connect any other device to the Raspberry Pi using serial.
[1]: http://spellfoundry.com/2016/05/29/configuring-gpio-serial-port-raspbian-jessie-including-pi-3/
Thanks for sharing this!
