Is it possible to communicate over the serial port (ttyACM0) on the RaspberryPi using Particle? The port works fine and I can communicate over it using both javascript and python running on the RPI, just not using Particle.
Alternatively, is there way to use a Particle app to send data to javascript or python program running on the RPI?
I tried basic serial commands similar to what you suggested, but could see no results on the attached serial device which at this point is just an Arduino attached via a USB cable for testing purposes. Any other suggestions?
