This is really frustrating! I have been programming in Basic for years…C++ is NOT BASIC!
you should post your code using Code Tags.
preface you code with back ticks like this:
```cpp
put your code in here
and put those at the end.
PS it looks like you have unmatched curly braces....
[quote="stephenscott, post:21, topic:32091"]
C++ is NOT BASIC!
[/quote]
thank God
Here is the code after finding the bad bracket.
pinMode(D6, INPUT_PULLDOWN);
pinMode(D5, INPUT_PULLDOWN);
if (digitalRead(D6)) {
uint32_t ms = millis();
Particle.publish("pizza test", "trig D6", PRIVATE);
while (digitalRead(D6) || millis() - ms < 1000)
if (digitalRead(D5))
Particle.publish("pizza test", "trig D5", PRIVATE);
while (digitalRead(D5) || millis() - ms < 1000);
Particle.process();
The error:
/workspace/pizza_4_29.cpp:18:42: error: ‘ms’ was not declared in this scope
Thanks for your help!
Try this instead (and observe the changed indentation which makes it easier to see what belongs where and where we are missing curly braces)
while (digitalRead(D6) || millis() - ms < 1000) Particle.process();
if (digitalRead(D5)) {
while (digitalRead(D5) || millis() - ms < 1000) Particle.process();
You had some issues with a wrongly placed semicolon and several missing curly braces
Thank you! That worked like a charm! Now, to do some homework on learning C++
