Photon / Ubidots Code for Switch monitoring
Hi all,
Help! Started using the Ubidots service which seems like a great place for monitoring your IOT devices.
I can get the Photon running with the light sensor demo fine but cant seem to merge my code into it The Code is below, all I am looking to do is detect a microswitch button press and then send that to Ubidots:
#include "HttpClient/HttpClient.h"
// This code is based on the original Http Example by nmattisson, see https://github.com/nmattisson/HttpClient
#include "application.h"
#define VARIABLE_ID "56b89034762542395061c3f1"
#define TOKEN "hvfS6EgvocbmvcyL8bU21KR46IfxTT"
HttpClient http;
int switchPin = D2; // MicroSwitch is connected to D2
int val; //variable for reading the pin status
int buttonState; //variable to hold the button state
unsigned int  counter = 0;
char          msg[1024];
unsigned int nextTime = 0;    // Next time to contact the server
http_header_t headers[] = {
  { "Content-Type", "application/json" },
http_request_t request;
http_response_t response;
  pinMode(switchPin, INPUT); // Initialize D2 pin as input
  buttonState = digitalRead (switchPin); // read the intial state
  request.hostname = "things.ubidots.com";
  request.port = 80;
  request.path = "/api/v1.6/variables/"VARIABLE_ID"/values?token="TOKEN;
  if (nextTime > millis()) {
    return;
  // Read sensor value
    val = digitalRead(switchPin); //read input value and store it in val
    if (val != buttonState); {       //the button state has changed!
      if (val == LOW) {              //check if the button is pressed
        counter++;             //increment the button presses variable
        Serial.println("Sending data ...");
        request.body = "{\"value\":" + String(switchPin) + "}";
        // Post request
        http.post(request, response, headers);
        Serial.println(response.status);
        Serial.println(response.body);
        buttonState = val;               //save the new state in our variable
        nextTime = millis() + 1000;
The code compiles and flashes OK.
Thanks for the help all.
N
Does your code ever go inside the “Read sensor value” part of loop() - it looks like your missing an else.
This semicolon if (val != buttonState);<---- is a typo and means your program will not flow as you expect.
Your posting switchPin, did you mean to post val?
I’m not sure what the point of counter is?
I am not sure exactly what your trying to achieve but I think the logic between buttonState and val needs to be looked at again. Mainly whether buttonState = val; should be inside your if clause.
Can you let us know what your desired behaviour is? i.e. notification every time button state changes/notification every time every time button is pressed/notification every time button is released etc.
Maybe something like this:
  if (nextTime <= millis())
    if (val != buttonState) //the button state has changed!
      if (val == LOW)
        request.body = "{\"value\":" + String(val) + "}";
        // Post request
If you have no external pull-resistor you'd need to use INPUT_PULLUP or INPUT_PULLDOWN to prevent your pin from floating when the switch is open.
And of course the above :wink:
This might seems silly, but how are you supplying current to the button that you are reading?
pinMode(somePin, OUTPUT);
digitalWrite(somePin, HIGH);
Needless to say, if the pin you are reading has no supply current it won’t change states when pressed and therefore won’t send the update to Ubidots.
I have a push button connected to D5.
The code below work for me.
#define VARIABLE_ID "yourVAR_ID"
#define TOKEN "yourToken"
HttpClient http;
//boolean buttonPush = false;
int buttonValue1 = 0;
int buttonValue2 = 0;
    pinMode(D0, INPUT);
    pinMode(D5, OUTPUT);
    digitalWrite(D5, HIGH);
    request.port = 80;
    buttonValue1 = digitalRead(D0);
    if (buttonValue1 != buttonValue2) {
            request.body = "{\"value\":" + String(buttonValue1) + "}";
            buttonValue2 = buttonValue1;
            // Post request
                return;
You either hard wire it to 3V3 or GND or use a seperate supplyPin, but usually option one is the easiest and common one and most likely the option the OP has chosen.
Yes I hardwired to 3v3 and then the other to GND
Thanks for the advice
I had it all working with the particle dashboard (using a different version of code) using particle.publish which was great.
Thanks all for the advice I will give it a try and let you know if it all works
Thanks. Yes your right I’m wanting to get a notification each time the button is pressed, will give your example a go
Thanks a lot for the code example.
Struggling to get it to verify though - keep getting the error message:
You need to import that library from the Libraries drawer (bookmark icon)
https://docs.particle.io/guide/getting-started/build/photon/#using-libraries
Silly me, thanks.
