Can’t seem to find anything on this error while searching. And no CLUE why they would REMOVE the token from view on the Web IDE
Output from my console.
PS C:\Users\Steve> particle token list
Checking with the cloud…
? Using account xxxx@xxxx.com
Please enter your password: [hidden]
! Error in particle-cli:
! processNextTick is not a function
! See C:\Users\Steve\AppData\Local\particle\error.log for more info.
PS C:\Users\Steve>
And the error log
2020/05/20 22:28:08 Time since last update 30m18.165573s, update in block
2020/05/21 05:28:14 TypeError: processNextTick is not a function
at emitReadable (C:\Users\Steve\AppData\Local\particle\node_modules\particle-cli\node_modules\request\node_modules\readable-stream\lib_stream_readable.js:419:21)
at onEofChunk (C:\Users\Steve\AppData\Local\particle\node_modules\particle-cli\node_modules\request\node_modules\readable-stream\lib_stream_readable.js:407:3)
at readableAddChunk (C:\Users\Steve\AppData\Local\particle\node_modules\particle-cli\node_modules\request\node_modules\readable-stream\lib_stream_readable.js:176:5)
at BufferList.Readable.push (C:\Users\Steve\AppData\Local\particle\node_modules\particle-cli\node_modules\request\node_modules\readable-stream\lib_stream_readable.js:157:10)
at BufferList.destroy (C:\Users\Steve\AppData\Local\particle\node_modules\particle-cli\node_modules\request\node_modules\bl\bl.js:211:8)
at Request. (C:\Users\Steve\AppData\Local\particle\node_modules\particle-cli\node_modules\request\request.js:1027:14)
at Request.emit (events.js:311:20)
at IncomingMessage. (C:\Users\Steve\AppData\Local\particle\node_modules\particle-cli\node_modules\request\request.js:969:12)
at IncomingMessage.emit (events.js:323:22)
at endReadableNT (_stream_readable.js:1204:12)
2020/05/20 22:28:14 Time since last update 30m24.1247952s, update in background
