After doing more reading on the P1 vs Photon, I’m realizing that Photon is more appropriate for my current needs (small run of prototypes). However, I’ve ordered a roll of P1’s in the first batch.
Anybody interested in trading their Photon for a P1? Ideally somebody would trade me 10 x Photons for my roll of 10 x P1, but I’ll do one at a time if I need to. (I haven’t received my P1s yet, but I’m assuming I can split them out easy enough.)
I’m happy to cover the difference in cost between the modules.
What are you reasons for wanting a Photon over a P1? Are you pretty capable when it comes to soldering? I only ask because if you are mainly interested in things like breadboard compatibility a breakout board, something I already need to do, could be created which gave you that functionality. Simple things, like buttons, an RGB LED, etc could be added as well
Pretty much what you listed: breadboard, mode and reset buttons, status LED, and USB power.
I don’t have a problem soldering so I’m interested in your breakout board. However it seems like getting that going is going to be more pain than just using a Photon.
Probably true but breakout boards could be quite cheap. The cost is in time to solder everything, source components, etc.
If you can get by without a lot of components (use the breadboard power rails, use your own RGB Led, your own buttons), and mainly leverage the breadboard compatibility a P0/P1 breakout board makes a lot of sense. If you are trying to re-create the photon then I would just pre-order one or try your trade
[Edit] I would probably look into two breakout boards: one for the P0/P1 and one for all the extra stuff which you can populate as you need to
