Was just curious if you guys were thinking about this.
What do you mean by that?
The P1 is already as close to a Photon as goes.
On the other hand you can order headerless Photons that can be SMDed due to the castellated edges (and you’ll find some extra solder pads underneath)
True, I use the P1 all the time. Just takes longer to solder to a board. I like having the extra I/O, and thought it would be nice to have the same type PCB as the Photon, but with the additional I/O.
