Tracker - Is there any way to turn off Blue GPS LED?
Hi, is there any way to turn off Blue GPS LED?
I was able to turn off Cloud LED using RGB.brightness(0); but it has no effect on the Blue GPS LED.
RGB.control(true);
delay(1000);
RGB.brightness(0);
delay(1000);
RGB.control(false);
Thank you.
You should be able to call from your code:
GnssLedEnable(false);
The header file should be included with the standard Tracker Edge includes.
Thank you, it works like a charm :stuck_out_tongue:
