[SOLVED] Control "charge" led on Tracker One - answer: not possible
Hello Particle Forum,
I would like to control the behavior of the “charge” led on the Tracker One.
Is there a way to do this in the Tracker Edge OS?
It is not possible to change the behavior of the charge LED. It’s connected to the STAT pin on the bq24195 PMIC and not under software control.
Thank you for the quick reply @rickkas7!
