Tone for R-Pi supported?
Is Tone() supported for the Raspberry Pi? I tried but it would not compile.
If you use Tone() you'll also get compile errors on native Particle devices since the function call would actually be tone().
However, I'm not sure it's fully supported since I can't see any documentation on the PWM enabled pins on RPi.
You may also want to have a look at this post
Thank you - helped more than you might know!
