I want to create a simple recipe similar to this example using the tinker-API
On the webinterface it is "D0, HIGH" (in the text field, without quotes).
My problem is, that I simply do not know how to formulate it.
The name of the function you want to call; ex: for your lighting project you may name your function LED
I have chosen "digitalwrite" and my core from the menu. That's ok, I presume.
But the second part just not works
... with input (Function Input)
Unrecognized Ingredient: {{"D0,HIGH"}}
{{"D0,HIGH"}}
Whatever that function takes as an input, ex: color of LED, brightness of LED
(The IFTTT-website shows explicitly "& quot ;" after "HIGH", not the qote itself, like the forum's page here)
Anyway: How would I use these double brackets to get a "HIGH' on D0?
Yes, stupid me.
I just figured that out myself and typed it in.
However, the injection of {{BODY}} and the comment:
is confusing.
Now it has become clear: The function still takes a string as its only argument, which still can't exceed 63 characters.
This string can be either placed directly, or as message body with {{BODY}} or else.
If the recipe is tagged "#switch" and the input is 'BODY", then the string is the complete message body.
