Is it possible to use both, the particle cloud AND send messages to a TCP/IP Address using the TCPClient library at the same time? Or do I have to disconnect from cloud and everything to make it work?
Hi @frlobo
You can use both at the same time. You can even have more than one TCP/IP client running but there is a limit on how many you can have.
Great!! I only need one connection so I think it won’t be a problem
Thanks for the help @bko!
How many TCPClient’s can you have on an Electron?
You can have 7 of all types of sockets, client, server, TCP and UDP combined on the Electron.
@rickkas7, is that 7 total including the cloud connection or 7 available to the user?
I wondered about that too. I’d guess probably 6 available to the user, but I don’t know that for a fact.
@rickkas7 thanks, I am using two at the moment but will want an extra one
