Tachyon FTDI USB-serial support
Hello,
Are FTDI USB to serial devices supported? Attempting to connect to an FT232RL device but no ttyUSB devices are showing up in /dev
It shows as connected in lsusb but nothing in dmesg. ftdi_sio is not found with modprobe and apt install linux-modules-extra-5.4.219 doesn’t have it either.
Bus 005 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 004 Device 003: ID 343c:0000
Bus 004 Device 006: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 004 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I wasn’t able to get the system to recognize it inherently, but if you’re using python you can use pyftdi and talk to it directly.
I got the vendor/product IDs like you did, and then I used
ftdi://[VID]:[PID]/1?baudrate=[baudrate] as the device URL, but I’m now realizing I could’ve just used ftdi://::/1?baudrate=[baudrate]too.
