What are the operating temperatures for the Tachyon? What other environmental conditions do I need to consider running this outdoors in a waterproof enclosure?
| Parameter | Minimum | Maximum | Notes |
| Recommended operating temperature | -17°C | +65°C | 1 |
| Battery charging enabled | 0°C | +55°C | |
| Storage temperature | -40°C | +85°C |
1Device will perform thermal shutdown below -20°C or above +70°C.
This information is now in the Tachyon datasheet as well.
