Hey, I just want to double check, I've been getting some occasional cloud disconnects and I want to save them on EEPROM with timestamp when they occur and then retrieve with simple function. Can you check my code for any issues? Thank you
#include "Particle.h"
time_t EEPROM_Value;
const int EEPROM_ADDRESS_cloud_event = 10;
int controlPnl(String command);
SYSTEM_THREAD(ENABLED);
void cloudEventHandler() {
time_t timestamp = Time.now();
EEPROM.put(EEPROM_ADDRESS_cloud_event, timestamp);
Particle.connect();
waitUntil(Particle.connected);
Particle.function("controlPnl", controlPnl);
System.on(cloud_status_disconnected, cloudEventHandler);
int controlPnl(String command) {
if (command == "check_last_disconnect") {
EEPROM.get(EEPROM_ADDRESS_cloud_event, EEPROM_Value);
delay(250);
Particle.publish("Timestamp", String((long)EEPROM_Value), PRIVATE);
return 1;
return -1;
