Argon or Boron is Particle.disconnect() needed?
I am not sure from the documentation or forum if I need to include the Particle.disconnect() statement. What should I do?
void setup()	{
    Particle.connect();
	waitFor(Particle.connected, 60000);
	//	Let’s say we are ALWAYS connected here.
}//	END setup()
void loop()	{// At some point we get disconnected from cloud
	if (Particle.connected() == false) {// NOT connected to Particle cloud
		Particle.disconnect();// is this statement required? or can I comment it out?
		Particle.connect();
	} else {
		doStuff();
}//	END loop()
If you’re already disconnected, there’s no reason to disconnect again.
Also, you could simplify that line with:
if !Particle.connected()
