I am trying to diagnose some general permanent disconnection states of remote Electrons. I've been trying to reproduce my issues, but in doing so I stumbled upon this issue. If (in SYSTEM_MODE(AUTOMATIC)) I call Particle.disconnect(), the device permanently disconnects from the Particle cloud despite an attempt to call Particle.connect again.
Firmware: 0.6.4
3rd Party SIM Card
#include <MQTT.h>
STARTUP(cellular_credentials_set("hologram", "", "", NULL));
//MQTT Config
byte server[] = {REDACTED};
MQTT client(server, REDACTED, callback);
String truncated_deviceID = Particle.deviceID().substring(4); // get a 20char version of the device ID to match the length constraint for the MQTT ID for compatibility
const char* MQTT_ID = truncated_deviceID; // c: chicago
#define MQTT_TOPIC_BASE REDACTED
const char* MQTT_TOPIC_error_data = MQTT_TOPIC_BASE "_error_data";
// Dummy handler to receive callback message from MQTT
void callback(char* topic, byte* payload, unsigned int length){};
bool keepAlive_set = false;
const uint32_t MQTT_msg_interval = 5000; //ms
uint32_t MQTT_time_last_sent;
uint32_t MQTT_msg_counter;
MQTT_time_last_sent = 0;
MQTT_msg_counter = 0;
if (!keepAlive_set && Particle.connected())
Particle.keepAlive(30);
keepAlive_set = true;
if (!Particle.connected())
Particle.connect();
else
Particle.process();
if (!client.isConnected())
client.connect(MQTT_ID);
else
client.loop();
if ((millis() - MQTT_time_last_sent) > MQTT_msg_interval)
client.publish(MQTT_TOPIC_error_data, "Test Heartbeat #" + String(MQTT_msg_counter) + "; Particle.connected()=" + String(Particle.connected()));
MQTT_msg_counter++;
MQTT_time_last_sent = millis();
if (MQTT_msg_counter == 10)
Particle.disconnect();
As indicated by the logs below, Particle.connected() continues to return true. I understand that it takes a few calls to Particle.process() to update, but after 30 minutes (just in case the keepAlive wasn't set properly) there was no change in state.
REDACTED : Test Heartbeat #0; Particle.connected()=1
REDACTED : Test Heartbeat #1; Particle.connected()=1
REDACTED : Test Heartbeat #2; Particle.connected()=1
REDACTED : Test Heartbeat #3; Particle.connected()=1
REDACTED : Test Heartbeat #4; Particle.connected()=1
REDACTED : Test Heartbeat #5; Particle.connected()=1
REDACTED : Test Heartbeat #6; Particle.connected()=1
REDACTED : Test Heartbeat #7; Particle.connected()=1
REDACTED : Test Heartbeat #8; Particle.connected()=1
REDACTED : Test Heartbeat #9; Particle.connected()=1
REDACTED : Test Heartbeat #10; Particle.connected()=1
REDACTED : Test Heartbeat #11; Particle.connected()=1
REDACTED : Test Heartbeat #12; Particle.connected()=1
REDACTED : Test Heartbeat #13; Particle.connected()=1
REDACTED : Test Heartbeat #14; Particle.connected()=1
REDACTED : Test Heartbeat #15; Particle.connected()=1
REDACTED : Test Heartbeat #16; Particle.connected()=1
REDACTED : Test Heartbeat #17; Particle.connected()=1
REDACTED : Test Heartbeat #18; Particle.connected()=1
REDACTED : Test Heartbeat #19; Particle.connected()=1
REDACTED : Test Heartbeat #20; Particle.connected()=1
In general, I've been seeing some issues with my devices where my remote devices in spottier service permanently disconnect from the Particle cloud, and then eventually (could be minutes or days later) stop sending data altogether. I'm trying to simulate various states of disconnection to try and reproduce my problems and this seems to be step one in figuring out what my actual root cause is.
The docs state:
In automatic mode, the user can still call Particle.disconnect() to disconnect from the Cloud, but is then responsible for re-connecting to the Cloud by calling Particle.connect().
The docs also say that Particle.connected() should:
Returns true when connected to the Cloud, and false when disconnected from the Cloud.
This does not seem consistent with the behavior I'm seeing. Am I missing something fundamental here, or is Particle.connected() not returning it's expected value?
