Switch() Case Multiple Values
Are multiple values for switch() statement allowed?
Here’s my example:
int i;
for(i=0;i<5;i++)
    switch (i)
             case 0,1,2:
                // do something
              break;
              case 3,4:
                // do something
               break;
@jdugat, I believe the correct syntax would be:
    switch (i)
             case 0:
  	     case 1:
	     case 2:
                // do something
              break;
             case 3:
	     case 4:
                // do something
               break;
However, you can try to compile with your original syntax to see if it works. :smiley:
Your version works mine does not. Thanks for the help!
