I’m trying to do a switch(software) with the readings of multiples inputs, so that depending on the digital reading of this inputs a specific case of the switch must execute.
when trying to compile it, error appears:
intentomanu.ino:100:19: switch quantity not an integer
Could someone lead me into the right way to do it?
int E3 = D7;
int E2 = D5;
int E1 = D4;
int E0 = D3;
int Inputs[4] = {D7,D5,D4,D3};
switch (Inputs)
case 1: //d7=0, d5=0, d4=0, d3=1
message();
break;
case 2: //d=0, d5=0, d4=1, d3=0
message2();
break;
//and so on
The switch statement needs the (integer) variable in brackets, to be matched to the value in each case statement. In this code snippet the value (Input) is an array and therefore will not match to 1: or 2:
So one way of doing this could be: (NB - not tested on a device)
enum inputs_enum {E0, E1, E2, E3, numOfInputs}; // create a list of aliases for 0, 1, 2, 3 & 4
int Inputs[numOfInputs] = {D3,D4,D5,D7}; // pins corresponding to inputs
void message(int messageNum)
switch(messageNum)
case E0: // matches to 0 from its position in the enum above
Serial.println("E0 is High");
break;
case E1: // matches to 1 from its position in the enum above
Serial.println("E1 is High");
break;
//etc
Serial.begin();
// get values
for (int n = 0; n < numOfInputs; n++)
if (digitalRead(Inputs[n]) > 0) // if the input is detected
message(n); // send message for that input
Particle.process();
Thank you, I did understand the part of matching the switch statement to the value, notice my error. But, with the inputs E3,E2,E1,E0 ; I want it to be as a binary number from 0(0000) to 15(1111), depending on the digitalRead of the inputs it will be the switch case
for example:
If E3=0, E2=0, E1=1, E0=1 it will be case 3 of the switch.
You cannot have cases like this (x, y, z). A construct like this will evaluate to the last item in the list hence you got the duplicate case of 0 (as of 0,1,0 -> 0 vs. 0,0,0 -> 0).
You can write your binary values 0b0010 tho`.
In your previous attempt you need to (re)read your pins over and over again in loop() not only once during initialisation (which I’d not do at all but init to -1 to indicate a disallowed value).
BTW, when using buttons or switches you need to add pull-resisotrs (internal or external) to ensure a discrete level while the switch is not closed.
