I was trying to reload the bootloader on an Eseries via SWD and received the below error when trying to connect to it. How can the write protection be disabled?
09:08:33 : Device ID:0x411
09:08:33 : Device family :STM32F2xx
09:08:33 : Can not read memory!
Disable Read Out Protection and retry.
09:08:47 : [electron-bootloader@1.5.1+lto.bin] opened successfully.
09:08:47 : [electron-bootloader@1.5.1+lto.bin] checksum : 0x00175364
09:08:56 : Read out protection is activated.
09:09:13 : Read out protection disabled.
09:09:13 : Some flash sectors are write protected.
The write protection will be disabled then restored after flash programming
in case there is no option bytes segment within the file.
09:09:14 : Device memory program canceled
09:09:20 : Can not connect to device!
09:09:23 : Disconnected from device.
