I have a project like this:
- a custom library called "MyLib"
-this has a library dependency defined in the library.properties like this 'dependencies.SparkJson=0.0.2'
-It has another dependency, but this library needed to be customized a little. therefore it is not in the library.properties. It is in a subfolder "lib/CustomizedLibrary"
When I compile and run the code from the usage examples I provided in the MyLib library, everything works.
But when I add the library to another particle project and compile it, it says
In file included from /src/OtherProject.cpp:8:0:
lib/MyLib/src/mylib.h:15:18: fatal error: CustomizedLibrary.h: No such file or directory
#include "CustomizedLibrary.h"
compilation terminated.
When I type "particle library view MyLib", it gives me the path of the library that the compiler uses (I guess).
C:\Users%USER%\Documents\Particle\community\libraries\MyLib@1.0.3
All the files are there.. I don't get why it doesn't work.
What can I do to make this work?
