Stuck at setup.particle.io
I am trying to setup an Argon, and it is showed as successful in console already (I can ping it, etc). However in this webpage, it is still showing this… (see below image)
I am also following this tutorial page: https://docs.particle.io/quickstart/argon/ to setup with the Starter project. I am clueless about electronic, and hope to get some guidance on how to put in the miniboard, transistors, etc.
Thank you…
You can find some basic electronics tutorials here
https://docs.particle.io/tutorials/hardware-projects/hardware-examples/argon/
Great! Thanks for the link and quick response.
I also did setup from my Android Samsung S9 device. It is already listed under “Your Devices” and I can see it has a “Tinker” on the right side of the list.
If it’s already working, I wouldn’t worry too much about that setup page anymore :wink:
