Hi all,
I am trying to create a labview interface that listens to the particle cloud stream and just displays the data.
when i type this in a command line:
curl https://api.particle.io/v1/events?access_token=<>
I can see all the data from everyone’s stream. But I cant seem to get this same data in Labview using the standard HTTP vis. ( I do have most of all other functionality implemented)
any hints or suggestions on how to do this?
