//declared like this at top of source
//const char cmdOn[] = {"on"};
//const char cmdOff[] = {"off"};
void processBuffer() {
int len = strlen(readBuf) + 1;
char copy [len];
snprintf (copy,len, "%s", readBuf);
//values look good when printed
Serial.printlnf ("[%s] [%s] [%s] Received from Particle", copy, cmdOn, cmdOff);
//none of these strcmp tests work
if (strcmp(copy,"on") == 0) {
digitalWrite(LEDD7,HIGH);
if (strcmp(copy,"off") == 0) {
digitalWrite(LEDD7,LOW);
if(0==strcmp(copy,cmdOn)){
if(0==strcmp(copy,cmdOff)){
//but this does
if(copy[0]=='0'){
if(copy[0]=='1'){
Your code has a lot of if, but no else. Could it be that you are accidentally overwriting the result of other if-cases than you’re expecting?
I would write this code like this:
} else if (strcmp(copy,"off") == 0) {
} else if(0==strcmp(copy,cmdOn)){
} else if(0==strcmp(copy,cmdOff)){
} else if(copy[0]=='0'){
} else if(copy[0]=='1'){
} else {
Serial.println("should not happen, unless all above failed");
Also, have you tried testing if the string also contains a non-visual ASCII character like \n, \r or \0? That’s likely what is causing the problem.
Just add this snippet to type out the ASCII character number of your string:
Serial.println("String start:");
for( int i=0; i<len;i++)
Serial.println( copy[i], DEC);
Serial.println("String end!");
J
Checking now Thanks!..
[on
][3] [on][2] [off][3] Received from Particle
Your Right there is an extra char the \r or \n
Answered! Fixed thanks to you jenschr. I test the len and if ok I do a strncmp and now it works. I now have a serial cmd parser.
You can also use strncmp() like this
if (strncmp(copy, "someString", strlen("someString") == 0)
and to save yourself some writing you can define a macro for that
#define STRINGCOMPARE(str, literal) strncpy(str, literal, strlen(literal))
if (!STRINGCOMPARE(copy, "someString))
