Hi all - I haven’t quite managed to work out a replication for this yet but I am posting it anyway to check if anyone has observed the behaviour I am seeing.
We have three photons running in our development product, one of them running 0.4.4 firmware and two of them 0.4.5 firmware as of last week. We pulled in 0.4.5 to get some of the bug fixes, hence our mixed environment.
The behaviour we see is a seemingly random lock up of the main application loop - we can determine this because the device becomes unresponsive and we no longer see a small amount of serial output that the main loop prints. The onboard LED flashes cyan when this happens.
We had previously saw this flashing cyan LED when there was the ‘zombie photon’ issue (I think this was fixed in 0.4.4) but in that case the main application loop was still running, we just couldn’t connect.
We run in MANUAL mode and handle process and connections in a function call from the main loop:
void checkConnectionStatus(){
if (Spark.connected()) {
Spark.process();
if (millis() - oldTime >= 2000) {
if (retryCount < 10) {
if (!WiFi.ready()) {
setDeviceState(DEVICE_WIFI_CONNECTING);
WiFi.connect();
retryCount++;
else if (!Spark.connected()) {
Spark.connect();
retryCount++;
else {
WiFi.off();
retryCount = 0;
WiFi.on();
oldTime = millis();
A note on our environment because if this is connection related, it may be relevant - we have about 30-40 clients on the access point (including the photons) and the signal strength where the photons operate is about 35-45%.
