I was looking at this SPI image and see that there is an arrow pointing out for MOSI but all others are pointing into the the pin. Does this mean that it doesn’t generate it’s own SCK or is this arrow the wrong way?
Kind regards
James
Kind regards
James
@Jamjardavies I’m fairly sure this arrow is just pointed the wrong direction. @mohit is that correct?
Thanks @Jamjardavies! I’m pretty sure both SCK and SS should be pointing away from the Core. Since the Core is functioning as master of the SPI line, the only feedback from other boards is on the MISO line.
Thanks for the update, I thought I’d point it out.
Kind regards
James
@Jamjardavies We’ve fixed the image. Thanks!
