I’ve been trying to read some data from SPI, but the SPI on the core only seems to be clocking through the first three bits, instead of a full byte. I’ve tried different SPI modes and clock dividers, but I can’t seem to get it to read a full byte. Am I doing something wrong here?
Hi @mattdot, Is this all of the activity you ever see on SCK? What is ENABLE hooked to, because your code doesn’t attempt to control the SS (latch) pin A2.
I was using D7 to enable the slave and not SS. Changing to using SS seems to have fixed the issue. While I see that I should be using SS, I still don’t understand why not controlling SS would change the clock to only 3 cycles. Thanks for your help!
Honestly I don’t see any reason it shouldn’t work with D7. The SPI routine does set SS to an output and set it HIGH, but doesn’t do anything else with it from what I could tell.
It really shouldn’t matter, but maybe try D6 just in case the LED is messing things up. I doubt it though.
Do you expect 0x03 on MISO? Looks kind of strange. I think your Logic Analyzer is decoding it wrong, as MODE0 should be clocking on the rising edge, so should be 0x01.
